---how to take off my spoiler----
hammer and chisel........then grind down the holes and weld them, some bondo, sand sand sand.......primer primer, sand with 400 grit, then primer with heavy coat....then some more 400 then base coat, then 1200grit, then clear coat.......
IMO, you should just leave it be. I actually don't mind the g2's with stock spoilers. But anyway, the spoiler should unbolt from underneath the hatch (or atleast thats how they're mounted in G3's) and Kragen carries plugs that should plug up the mounting holes.
There should be four bolts holding it on. You'll be able to see them when you open the hatch. You can plug the holes up with rubber grommets from home depot or something.
and your done unless you did it wrong.....follow directions carefully!
