Please Help! I need to learn how to remove Integra Door and Install new one!
Old Apr 26, 2007 | 03:41 PM
CrazyRexBoy's Avatar
Default Please Help! I need to learn how to remove Integra Door and Install new one!
hey bros...recently someone hit my passenger side door and i had to get a new one... so i know this might sound like a noobie question or what not but please...
This is regarding my 99 GSR 2 Door Coupe
1. All 94-01 Acura Integra doors fit as long as power windows,locks etc right?
2. How do you remove a Passenger side door Step by step?
3. How do you install step by step?
thank you so much guys...
Old Apr 26, 2007 | 05:37 PM
Orange's Avatar
Default Re: Please Help! I need to learn how to remove Integra Door and Install new one! (CrazyRexBoy)
Haven't touched a teg in a while, but here are some general removal items. Remove the speaker cover and disconnect the speaker. Remove the power controls and disconnect. Remove the door handle guard. Use a panel remover or just wear some cloth gloves. Pop the door panel out from the bottom and run glove through bottom of panel. Then will have to push door panel slightly up b/c it's latched on at the window part. Disconnect the main door harness near the bottom door hinge. Pop the retaining pin right above the bottom door hinge. Unbolt the door hinges and that should be it. The thing that I had a problem with was removing the outside door handle to retain original key.... Basically at this point took door to garage... they painted it and put the door on.
Good Luck
Old Apr 26, 2007 | 05:58 PM
ls19integra95's Avatar
Default Re: Please Help! I need to learn how to remove Integra Door and Install new one! (Orange)
i just rebuilt my whole car, to take the door off your gonna have to take the finder liner off in the front so you can get a 10mm bolt thats attached to the fender in the tire well, then the three in the engine bay for the fender, you then gotta take the side skirt off to get the 2 bolts off from behind that on the bottom of fender and one more you have to get by opening the door, you need to take it off to get to the door bolts, you then pop the pin out of the door on inside of it attached to the car body, the unplug the wiring that goes to the edge of the door and then unbolt the door, you dont have to remove the speaker and inner panel to get it off, only to put onto your new door if needed
Old Apr 26, 2007 | 09:28 PM
Default Re: Please Help! I need to learn how to remove Integra Door and Install new one! (ls19integra95)
i see ....it doesnt sound that easy ...but at least i get the idea of what i need to do...thanks guys....appreciate all the help i can get...
Old Apr 26, 2007 | 09:40 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyRexBoy &raquo;</TD></TR><TR><TD CLASS="quote">i see ....it doesnt sound that easy ...but at least i get the idea of what i need to do...thanks guys....appreciate all the help i can get...</TD></TR></TABLE>
Once you get under the fender, the 3 pieces holding the door to the body,
unbolt the Middle one first, then the outer two, since they support the door.
cennouu
Dec 23, 2010 04:12 PM
Si_Prelude
Dec 12, 2005 06:32 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
Adampops
Aug 26, 2002 06:03 PM
sicilian2k1
Audio / Security / Video
Aug 21, 2001 03:52 AM
