Sunroof
I recently bought a 90 crx si. I was playing around inside and I tried to open the sunroof, opened fine. Then i tried to close it and it kept stopping and then finally completely stopped about halfway. So I messed with it a little (pushing on it) and it wouldnt budge. Then I came back about a half hour later I put it all the way back, and now it doesnt move at all. I cant even hear the motor anymore to move forward, but I can hear it if I press it to go backwards. Any ideas? I guess ill take apart the headliner and take out the frame and see what could be wrong, but I'd like to get an idea of what is wrong. Thanks.
search buddy
its the switch 80% of the time its been covered
take apart the switch and clean the terminals theres a write up on here
or try a new switch from thte junk yard!
there is a manual like screw to turn so you can manually close the sunroof
I did search, but I didnt find the same case as mine so I made this thread. Thanks for the advice though, I'll try it tonight. Also, where would this screw be located?
Modified by SamN at 5:44 PM 4/26/2007
