Need Hasport Motor Mount Bolt Measurments........
Old Apr 26, 2007 | 01:51 PM
SiR Inspired ED7's Avatar
Default Need Hasport Motor Mount Bolt Measurments........
I bought some motor mounts from a friend, but he told me that i could get the bolts at a Hardware Store. If any one knows the bolt Measurments & could help me out that would be great....
Thanx
Old Apr 26, 2007 | 05:50 PM
Crx Jimmy's Avatar
Default Re: Need Hasport Motor Mount Bolt Measurments........ (SiR Inspired ED7)
most of the stock bolts work. do you not have the stock bolts?
Old Apr 26, 2007 | 07:38 PM
Default Re: Need Hasport Motor Mount Bolt Measurments........ (Crx Jimmy)
Yes i do have the stock ones. But the only one's that work are for the mounts them selfs but the one's that go down onto the tranny & for the back mount that go's to the cross member cause they are to short
Old Apr 26, 2007 | 07:44 PM
Crx Jimmy's Avatar
you dont use bolts on the tranny I think there are supposed to be studs and they work with the stock studs already on the tranny.
Old Apr 26, 2007 | 08:31 PM
jdmcars.com's Avatar
The cables into an EF would require a bolt, not stud (as the cable trans have a stud plate that is used when installing into an EF using aftermarket mounts like the HaSport).
Take the proper stock bolts with you to have the thread n pitch measure to insure you get the proper thread bolt, then you can take the mount there as well so so them the thinkness to get the correct length.
Old May 5, 2007 | 09:40 PM
I got them already but thanx anyways...
dommyy13
Feb 6, 2013 09:46 PM
Linked
12
Mar 2, 2010 10:55 AM
GroundZer0 336
Jun 29, 2008 10:38 AM
eksteve
Apr 29, 2008 06:57 AM
DA-MAX
Nov 23, 2003 05:15 PM
