Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How do you put in different DRL?
Old Apr 26, 2007 | 11:08 AM
NoPainNoGain's Avatar
Default How do you put in different DRL?
I just bought 2500k Nokya 80W 2005 lights for my DRL's but cant seem to get behind the headlight. The passenger side I have a bit of room but not the driver side at all. I was wondering if anyone else has done this and possibly have an easy way of doing this. lol all i wanna do is change the bulbs. I thought of trying maybe to take off the wheels and try through the fender but just an idea. Any help would be appreaciated. Thanks
Old Apr 26, 2007 | 11:20 AM
FBPSidan's Avatar
Default Re: How do you put in different DRL? (NoPainNoGain)
Check your manual...it tells you to go through the fenderwell trim to change the bulbs
Old Apr 26, 2007 | 12:05 PM
Default Re: How do you put in different DRL? (FBPSidan)
oh now i feel dumb lol well thanks
Old Apr 27, 2007 | 12:04 PM
Curiously does anyone know if 80W will run well for DRL? Like is it too much Wattage? I dont think so but just to be safe.
Old Apr 27, 2007 | 02:16 PM
EK k kay's Avatar
Remove the coolant reserve tank. Just pull it upward.
Old Apr 27, 2007 | 06:00 PM
rsvmille's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoPainNoGain &raquo;</TD></TR><TR><TD CLASS="quote">Curiously does anyone know if 80W will run well for DRL? Like is it too much Wattage? I dont think so but just to be safe.</TD></TR></TABLE>
While the DRL is on the voltage to the high beam bulb is reduced, so i doubt a higher watt bulb will hurt it. However, if high beams are used alot it may blow a fuse here and there.
Old Apr 27, 2007 | 06:07 PM
TRE_'s Avatar
It'll be fine.
Old Apr 28, 2007 | 01:16 PM
Default Re: How do you put in different DRL? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Remove the coolant reserve tank. Just pull it upward.</TD></TR></TABLE>
I tryed pulling it upward but something is holding it down and i dont want to break anything. Just pulling is right out will still let me put it back in no problem without breaking anything?
Old Apr 28, 2007 | 01:56 PM
itz smokin's Avatar
I tryed pulling it upward but something is holding it down and i dont want to break anything. Just pulling is right out will still let me put it back in no problem without breaking anything?</TD></TR></TABLE>
you won't break anything... just pull harder. putting it back is easy.
Old Apr 28, 2007 | 05:07 PM
Rainy City's Avatar
Default Re: How do you put in different DRL? (itz smokin)
Scratched my hand for my friends headlights. I figured in the end its not that hard at all. You actually just have to position it correctly, the pass and driver side aren't exactly a mirror in terms of putting it in.
06civicoolie
Sep 28, 2007 08:45 PM
ProjeKt
Jun 16, 2006 06:14 PM
eagleclawracing
Jun 9, 2006 06:25 PM
badbeast
Apr 22, 2006 10:41 AM
PleaseHelp
Aug 18, 2005 08:20 PM
