CRX leaks water please help!
After getting my crx on the road I've been experencing puddles of water in the car, I'm not to sure where it's coming from, I thought it would be the sunroof since it's all messed up but it taped it down for now and It doesn't look to be coming from there, most of the water is on the passanger side, or behind the passanger seat. I think it may either be coming from the window, or the rear hatch and then moving up front, anyone ever have similar problems and anyone know a solution to this? I wish I could only drive the car when it was nice out, but I need the car for a daily driver, please any input or help would be appricated. I was thinking about starting by replacing seals, dunno if that will help or not. Thanks again in advance.
Check:
-tail light seals
-sunroof drain tubes (but it sounds like that isn't the issue)
-rear washer hole
-weatherstripping
I always say to check the tail lights first as they seem to be probably #2 in the cause of standing water.
-tail light seals
-rear washer hole
-weatherstripping
[QUOTE=91ed9]have someone go inside thecar and spray a hose at high power all around the car and have the guy inside the car look for the leak
x2
[x2
thanks guys I will check into all that, also it looks like water is leaking in threw the front doors almost by the speaker pods, anyone have any clue where that could be coming from? The passanger side is worse because I don't have a door panel on right now, but even the driver side looks like its doing it. Thanks again. Also it does seem that the rear washer nozzle is loose, I just checked it out, not sure if all the water is coming in there but probably some. How do I go about fixing it? or just replaced the nozzle with a new one and silicone it down? Also I probably have to pull the headliner to do this correct? Thanks
stangyaracing
12
Jul 23, 2004 02:52 PM
GroundZer0 336
Mar 15, 2003 05:29 AM
