GSR Swap into 94 Ls HELP!!!!!
Old Apr 26, 2007 | 09:33 AM
killacam661's Avatar
Default GSR Swap into 94 Ls HELP!!!!!
i just put a gsr into my 94 integra ls and it started right up.i still need to wire up the knock sensor and vtec(HELP PLEAASE!) into the ECU. when i took it for a test drive it lacks power. couldnt get up to 50 mph. i know the timing is off because when u put the gun on it and moved the dizzy to get it at 16degrees the motor ould almost die out. what do i need to do? and also my speedo doesnt work and i have taken it out and put it backi in like 5 times. Thanx all for the help!!!
94 teggy ITR b18c1
TypeRbuild718
May 11, 2007 07:58 AM
