sir front end conversion
Old Apr 26, 2007 | 08:25 AM
b16a3delsol's Avatar
Default sir front end conversion
What is the difference between an SiR and a usdm si? Thank You
Old Apr 26, 2007 | 08:44 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: sir front end conversion (lsdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdelsol &raquo;</TD></TR><TR><TD CLASS="quote">What is the difference between an SiR and a usdm si? Thank You</TD></TR></TABLE>
One was sold in Japan, the other was sold in the US.
There are many differences between the two but judging by your title you are referring to the front ends. If you are doing the SiR conversion you will need the fenders, hood, bumper, bumper filler, radiator t-bar, headlights and corner light, pretty much everything. Somebody correct me if I'm wrong.
And if you need any additional info just search for 'sir conversion' and you should find a few good threads about this.
Old Apr 26, 2007 | 08:48 AM
ludesrv's Avatar
They are expensive as hell, barely ever show up in good condition anymore, and have very minor differences. Almost not worth it.
But Wisco did say it all right. And listed everything. Only thing he missed is the fenders are the same as 90-91 other then the side marker hole, which you can cut out yourself to save like 200-300$.
Honestly, if money is an issue, these front ends go from 300-400$ in bad shape, to 1500-1700$ in mint shape (already here too).
I say get the UDSM SiR style CF hood, give it the more aggressive look without spending mad cash.
Old Apr 26, 2007 | 10:19 AM
CRX Toad's Avatar
This has been covered many times. Please use the search function for SIR front end, SIR conversion, JDM front end. Also make sure to select recent and archived threads specifically in the CRX/EF Forum.
Thanks
ghosthatch
82
Jan 16, 2010 07:08 AM
onlythruyoeyezz
Sep 18, 2006 08:37 PM
blackedoutgsr
Nov 19, 2005 10:46 AM
mini-cRx
Jul 25, 2002 07:16 PM
