FS: Fully Built B20 Vtec NA, Full swap. $4,500 or post offers...
Just Like i said Fully Built B20 vtec full swap. This swap put down 225whp and 162 lb-ft. This swap is very capable of making a hatch into a high 11 second ,NA, quater mile vehicle!!!
Swap Specs:
Motor:
B20z block
Eagle rods
Weisco pistons 12.5:1 Compression
Golden Eagle Block Guard
Tapped Oil Squirters
B16 PR3 Head
New Stock PR3 Valves
Toda Spec C cams
Toda valve springs and retainers
Spoon adjustable cam Gears
ITR intake manifold
Tranny:
B16 non-lsd
oem axles
shift linkages with short shofter
Exedy clutch & Flywheel
Electrical:
Engine harness
ECU is chipped
Spectacular Tune
put down 225whp/162lb-ft
Contact info:
E-mail is Soccrguy711@netscape.net
Or call @ 843-276-4175
Zach
Swap Specs:
Motor:
B20z block
Eagle rods
B16 PR3 Head
Toda Spec C cams
ITR intake manifold
Tranny:
B16 non-lsd
oem axles
Electrical:
Engine harness
ECU is chipped
Spectacular Tune
Contact info:
Zach
GnarKiller
Apr 29, 2007 04:06 PM
