Need an amp suggestion for a 10" Kicker Solo Baric L5
Old May 29, 2002 | 01:40 PM
JK882's Avatar
Default Need an amp suggestion for a 10" Kicker Solo Baric L5
I am planning on purchasing this sub along with a Panasonic MP3 headunit. What types of amps do you guys reccomend for this setup? Should I get a mono-channel amp or a 2 channel and bridge it? I don't want to spend a lot of money on an amp - somewhere around $300. What would be the best bang for the buck? The sub is 4ohms and the power range is 50-450 watts rms. Thanks
Old May 29, 2002 | 06:39 PM
b20guy's Avatar
Default Re: Need an amp suggestion for a 10" Kicker Solo Baric L5 (JK882)
From what I've heard, you need to feed the solo's a lot of power. Get the most you can afford.
Old May 29, 2002 | 06:41 PM
b20guy's Avatar
Default Re: Need an amp suggestion for a 10" Kicker Solo Baric L5 (m0bile)
Oh and you might want to look into MTX amps. Fairly inexpensive, and fairly powerful, good quality.
Old Jul 21, 2002 | 02:49 AM
RC211V's Avatar
Default Re: Need an amp suggestion for a 10" Kicker Solo Baric L5 (b20guy)
i only recomend MTX class D amps.
class d
anyother MTX multi channel
Old Jul 21, 2002 | 02:51 AM
RC211V's Avatar
why L5? if you are goin solo baric go all out and get the L7. well that is what i am doing. ahhahahahaha. also with my L7 i am going to use the kicker KX800.2. what you think?
Old Jul 22, 2002 | 07:01 AM
T3EMSI's Avatar
Default Re: Need an amp suggestion for a 10" Kicker Solo Baric L5 (JDMintegGSR)
Get a soundstream amp. 2 channel with at least 250 watts rms per channel at 2ohms.
I have the kicker 500.3. front two go to my bostons, no rear speakers, 12" solo sl7 with a wopping 450 WATTS RMS into that bitch.
CivHatchH22
Audio / Security / Video
Apr 12, 2004 09:21 AM
B16Drag
Jan 29, 2004 10:04 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
Calavera
17
Jun 24, 2002 10:30 AM
ShowSpeed
10
Dec 10, 2001 09:20 AM
