B18C5 questions
Old May 29, 2002 | 01:29 PM
Dokta's Avatar
Default B18C5 questions
Does anyone know how much a stock integra type-R flywheel weighs, or where I can find that info?
What are oil squirters on a B18C5? Where are they located, why are they there, and what do they do?
Are the oil pump and water pump on the B18C5 engines different than those on other B series engines? If so, what is the difference?
Old May 29, 2002 | 01:32 PM
sgT's Avatar
sgT
Default Re: B18C5 questions (Dokta)
15lbs
oil jets spray oil onto the bottom of the pistons to cool them
they are mounted at the bottom of the cylinder
pumps are different between b18c and the rest of the b-series line.
The b18c pump uses more pressure to flow more oil.
Old May 29, 2002 | 01:52 PM
SMSP's Avatar
Default Re: B18C5 questions (sgT)
Is there anything different between the pump rotors and body or does it just use a different bypass spring? If you want pressure from a standard pump just shim the spring.
Old May 29, 2002 | 01:57 PM
sgT's Avatar
sgT
Default Re: B18C5 questions (SMSP)
from what i have seen(since i have been doing a lot of pump work lately)
is that its just the bypass spring. The HELM says it flows more volume, but that
might just be a result of slightly higher pressure.
Old May 30, 2002 | 04:43 PM
Dokta's Avatar
Thanks for the answers.
So if I inserted a shim, or replaced the bypass spring on any other B series oil pump, it would be the same as the B18C oil pump. Cool.
How about the water pump? Is it the same deal, or are they all the same?
About the oil squirters, are they only one the B18C5, or are they on the GSR engine as well? Can they be installed on any B series engine? Where do they get the pressure to squirt the oil from, are there oil lines that run from the discharge of the pump or what?
rollb18c
10
Oct 26, 2015 01:29 AM
al3e
Texas -OK -LA (Sales)
Jul 25, 2005 02:20 PM
Griffin@Camtech
Apr 14, 2004 04:41 PM
Blown90hatcH
Sep 19, 2001 06:24 PM
