another quick question :D : making my new seats fit.
Old Apr 25, 2007 | 10:11 PM
88CRXowner's Avatar
Default another quick question :D : making my new seats fit.
okay so these are the new seats that i just got, but the problem is, i have an 88 and they are from a 90 or 91 crx. so yeah, my rails dont fit on the seats tightly. what approach can i take to fixing this? :D thanks in advanced.
http://mail.google.com/mail/?a...c8809
they make the interior look better i think.
edit: not sure if you guys can see that link?
Modified by 88CRXowner at 11:23 PM 4/25/2007
Old Apr 25, 2007 | 10:40 PM
shackler's Avatar
Default Re: another quick question :D : making my new seats fit. (88CRXowner)
well what you can do,this is what I did, is take apart the seats and swap the rails. but one thing I ran into was that the rails wouldnt work. so I took all the hard wear apart and it all fit together perfectly. but my seats now are too low andim a short fella so its hard to see over the dash. hahaha, but you can try this idk if you'll run into the same problem as me but I guess its worth a shot, eh?
Old Apr 26, 2007 | 05:34 AM
88CRXowner's Avatar
and this was on an 88/89 with 90/91 seats? you used the original brackets? because there is about 1/4" of space between the back holes on the rails and seats. i'm fairly tall so lower seats wouldnt be bad.
Old Apr 26, 2007 | 08:17 AM
shackler's Avatar
Default Re: (88CRXowner)
ya i have a 91 that had good seats in it and took them out and popped them into my 88 crx I know the rails are way off but all the inside hardware bolted right up
Old Apr 26, 2007 | 09:40 PM
88CRXowner's Avatar
so... yours work fine now? and they are secure?
Old Apr 26, 2007 | 10:04 PM
VRD^don's Avatar
why not do a seat pan swap? that way you can use the correct ralils..
Old Apr 27, 2007 | 06:21 AM
JLefevers's Avatar
Default Re: (VRD)
yes take your 88-89 seatrails and pans and put them on the 90-91 seats i have done this with 96 civic ex seats and worked fine. hope this helps and u get ur stuff in
Feli
Mar 19, 2010 03:14 PM
AlfieRoach
17
Feb 24, 2010 01:40 AM
uses0ap
Feb 23, 2009 06:22 PM
hahahahhah
27
Jun 10, 2004 09:18 AM
chadmasterc
Apr 29, 2003 03:54 PM
