Just a curioius question about VTEC
Old May 29, 2002 | 01:04 PM
type r 01-1063's Avatar
Default Just a curioius question about VTEC
is it possible to turn off vtec?
Old May 29, 2002 | 01:06 PM
Cal_Ripcurl's Avatar
New User
Default Re: Just a curioius question about VTEC (type r 01-1063)
So tell us, now why would you want to?
Old May 29, 2002 | 01:10 PM
Default Re: Just a curioius question about VTEC (Cal_Ripcurl)
not that i want to. just wandering of that possibility
Old May 29, 2002 | 01:11 PM
t's Avatar
t
Unplug the green plug at the VTEC solenoid.
Nate B's Avatar
unplug the vtec wiring from the ECU. bad idea though, and if you don't want VTEC you have some problems
Old May 29, 2002 | 01:35 PM
SurferX's Avatar
Default Re: Just a curioius question about VTEC (KILLERB18)
Just don't rev up past 5700 RPM. If the purpose of turning off VTEC is to drive like a ***** I would think you wouldn't rev up that high anyway.
Old May 29, 2002 | 01:47 PM
IntegraT's Avatar
Only on LS models
Old May 29, 2002 | 01:50 PM
Honda F1's Avatar
Default Re: Just a curioius question about VTEC (IntegraT)
Another method (a very stupid one) is unplugging your speedometer.
Old May 29, 2002 | 01:51 PM
AllMotorITR's Avatar
New User
Default Re: Just a curioius question about VTEC (HONDAF1)
Why would you want to do that or know of the possibility? Weaksauce..
Old May 29, 2002 | 01:54 PM
H-PIMP's Avatar
Default Re: Just a curioius question about VTEC (1 FAST R)
Unplug the speed sensor. Viola! No mo vtec Y0!@
Old May 29, 2002 | 01:59 PM
t's Avatar
t
Default Re: Just a curioius question about VTEC (H-PIMP)
also no more miles on your odometer, plus you wont knwo how fast your going
Old May 29, 2002 | 02:44 PM
to me for just even thinking of that question
Old May 29, 2002 | 03:36 PM
t's Avatar
t
Toda VTEC killers.
Old May 29, 2002 | 03:57 PM
NONKonformyst's Avatar
First off, why do you want to remove VTEC? If you're looking for that "VTEC Power Hump" throughout the power band that is possible. All you need to do is replace the cams with a custom setup of larger lobes on the high and low side. I believe TODA has something like this, but I don't know if it was just for their R or if it's for sale.
Old May 29, 2002 | 04:05 PM
Default Re: Just a curioius question about VTEC (95redLUDE)
guys, i have no intentions of turning of vtec.
like i just said "just a curious question...."
Old May 29, 2002 | 04:14 PM
Erik_Pb_Foot's Avatar
New User
VAFC would turn it off, or you could just unplug the VTEC solenoid (as stated above).
-Erik
Old May 29, 2002 | 04:56 PM
frogsr's Avatar
lol. hahaha.
Old May 29, 2002 | 09:06 PM
Mikes94's Avatar
Why does unplugging the speedometer stop VTEC engaging? I could possibly understand why unplugging the speed sensor would (although this would still be unusual would it not ... thought VTEC operates on RPM not speed?!?!)
Mike
Old May 29, 2002 | 09:44 PM
t's Avatar
t
Default Re: Just a curioius question about VTEC (Mikes94)
I am not sure if the original poster meant speed sensor not speedometer.
VTEC needs to see a certain speed, try reving your car in neutral and see if VTEC kicks in.
Old May 29, 2002 | 11:27 PM
TypeR Freak's Avatar
Default Re: Just a curioius question about VTEC (t)
I thought it just needed a load on the engine...You can be going any speed and if the car is in neutral VTEC will still not engage.
Old May 29, 2002 | 11:31 PM
poison's Avatar
Default Re: Just a curioius question about VTEC (frogsr)
lol. hahaha.
i hear that
Old May 29, 2002 | 11:35 PM
Honda F1's Avatar
Default Re: Just a curioius question about VTEC (poison)
You can't turn it off. Its a force that is all around us, it binds us...........
Old May 29, 2002 | 11:46 PM
ITRbroham's Avatar
shit post warrior
omg
Old May 29, 2002 | 11:55 PM
comptechgsr's Avatar
Default Re: Just a curioius question about VTEC (ITRbroham)
i jus took off my vtec last night along with my todas...
if u want an extra set you can have mine...
Twin-Vtec'd b-series engines run pretty strong
Old May 30, 2002 | 09:21 AM
New User
Default Re: Just a curioius question about VTEC (comptechgsr)
yea, i've heard you can even replace your "VTECH" solenoid with a bigger one and use synthetic VTECH fluid which they claim is good for up to 18 whp. anyone try this yet?
