Swap Help Please!
Old Apr 25, 2007 | 06:13 PM
gsrcivic619's Avatar
Default Swap Help Please!
I just did a 96 ls swap into my 97 civic.. I think we are using a 97 DX harness. We got pretty much all of the sensors hooked up except for the idle control valve above the manifold, and some other manifold sensor on the manifold. We can't find the plugs on the harness. If you guys are in or around the Bonita/Chula Vista area and you're a techy with wiring, please contact me. If anyone can help out it would be greatly appreciated. Car starts up but does not keep idle. Dies. Like i said before the idle control valve sensor is not hooked up neither is the other intake mani sensor. What route can i take? Thanks guys.
Old Apr 25, 2007 | 06:19 PM
ekb16's Avatar
i think that your harness has a 3 wire IAC so you would need to switch that into a 2 wire...get a wireing diagram and look for the idle control for a civic
Hoopdie91
Feb 18, 2018 04:39 AM
edd805
Oct 8, 2012 10:33 PM
Epidemic06
Jun 4, 2008 06:25 PM
VtecDA9
Jan 28, 2004 02:15 PM
