mpfi done but no fuel
dont with the mpfi conversion but no fuel ther is fuel getting to the fuel rail but not out of the injectors...im sure i have the injector wiring up but not sure about vaccum lines...if i dont hook up the map hoses up right will it make it not run..but that wont stop fuel from shooting out of the injectors right......and do the plugs on the injectors have to be in the right order if so wat are the color of wires coming off each injector plug?????
if you wired the injectors from the ECu it should be pinouts a1 a3 a5 a7
and they ahve to be in the right order/color
wire the yellow/black power wire to the injector box and from there all 4 re/black wires to the injectors to power them on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante »</TD></TR><TR><TD CLASS="quote">if you wired the injectors from the ECu it should be pinouts a1 a3 a5 a7
wire the yellow/black power wire to the injector box and from there all 4 re/black wires to the injectors to power them on. </TD></TR></TABLE>
the only wires goin from the injector plugs from my ecu are a3 and a7 like the guide tell you to do
i dont trust it that way. i feel more comfortable knowing the signal is coming from the proper ECU location.
thats how i have done countless swaps..
injector - pin - color wire
#1 A1 brown
#2 A3 Red
#3 A5 light blue
#4 A7 yellow
#1 A1 brown
#2 A3 Red
#3 A5 light blue
#4 A7 yellow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">then where will the wires from the dx injectors go???</TD></TR></TABLE>
so wat do i do with the old dx injector wires just leave them and not even connect them since im useing pin a1 and a5 from the ecu
I want to know this information also.
It would be nice if someone could explain this stuff in a post in a step-by-step kind of way. There are soooo many guides for this process that are confusing, and one good post could clear the air on soooooooo many misunderstandings.
Joe Yaerrd
Nov 13, 2015 04:50 PM
therest
37
Jan 9, 2013 09:16 PM
Pritos
Jul 2, 2001 06:55 AM
