wierd idle problem on start up and while driving.
Old Apr 25, 2007 | 03:37 PM
rayray NOT shanaynay's Avatar
Default wierd idle problem on start up and while driving.
ok guys. i have a 97 gsr. and everytime i turn on the car the idle will dip to about 500 then back up to about 700-800. everytime it dips, the car hesitates but still runs fine. when i drive it and i hit a stop light i throw it in neutral and it dips down to 500 and raises again. what can it be? i just had a full tune up about a month ago. thanks in advanced guys!
Old Apr 25, 2007 | 06:50 PM
Default Re: wierd idle problem on start up and while driving. (fourOHate.)
bump for some help
Old Apr 25, 2007 | 06:52 PM
Dogginator's Avatar
Daisy... Daisy...
A dirty IACV is a common problem.
Old Apr 25, 2007 | 06:56 PM
krytykalintentions's Avatar
Default Re: wierd idle problem on start up and while driving. (Dogginator)
hey i got the same problem,,, i clean out my IACV and even swapped a new one in but it still does the same thing any have any suggestions????
Old Apr 25, 2007 | 06:58 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: wierd idle problem on start up and while driving. (krytykalintentions)
Have you set the base idle?
Old Apr 25, 2007 | 07:05 PM
wat do u mean base idle??
Old Apr 26, 2007 | 03:26 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krytykalintentions &raquo;</TD></TR><TR><TD CLASS="quote">wat do u mean base idle?? </TD></TR></TABLE>
You warm the engine, turn off all accessories, disconnect the IACV, and adjust the idle screw on the throttle body to 500 +-50 RPM. You then shut off the engine, reset the ECU (it will havbe an IACV code stored), reconnect the IACV, and restart. The car should idle at 750 +-50 RPM.
Note: I am pulling the RPM numbers from memory. Double check the Helm manual.
Old Apr 26, 2007 | 04:19 AM
ill try that out 2day and let you know any change!
Junkyard2000
14
Nov 2, 2005 06:35 PM
ExAcc
Sep 20, 2005 10:49 AM
Shmolie
Jun 29, 2005 05:58 PM
