RDX Injector plugs
http://www.acurazine.com/
Check out the RDX forums. A coulpe months ago, I found some guy with a wrecked RDX who was parting it out. Not to sure if he's still selling some stuff, but it doesn't hurt to try.
Good Luck!
Good Luck!
I was told those are actually turn signal connectors. I am not sure what models they are off of but if you might cross reference the part number to find out. There may be the same part available with a different part #.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO »</TD></TR><TR><TD CLASS="quote">Damb! Thats PIMP! I order 4 of the tC clips this morning! I'll post some pictures are I get them installed!
K20a.org rocks!
Fixed.
K20a.org rocks!
</TD></TR></TABLE>Fixed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DemCrahzyColahs »</TD></TR><TR><TD CLASS="quote">K20a.org rocks!</TD></TR></TABLE>
Your totally right!!
FYI...although its been a MAJOR pain in the butt getting these clips from the dealership becuase they have been on back-order... I did finally get 2 of the 4 plugs ordered yesterday and can confirm 100% the plugs work GREAT on the RDX injector!!
When ordering the #90980-11875 from Toyota you only get the plug but it looks like the female spaid from inside of the OEM HONDA injector plug will come out and work inside the toyota clip, eliminating any cutting and re-wiring. Once I know for sure I'll let post some pics!!
Now if the other 2 will come in off the back order sheet I'll be ROCKING!!
OK...its 100% official! The Toyota PN#90980-11875 works perfect on the HONDA RDX injector. You will have to de-PIN your factory harness so that you can re-use the OEM spades found inside the OEM injector clip. These factory spades fit 100% perfect inside the Toyota plug!! The Toyota PN# DOES NOT come with the wire or spades so reusing the factory spades is a MUST!!
Anyways...since the motor is stock for now I'm running a very basic set-up and hoping to push about 7psi w/ the Kpro and hopefully we wont max out these injectors. I'll post some dyno numbers once I tune it over the weekend!
Anyone try this yet? It looks almost exactly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.diyautotune.com/catalog/f...eon-p-132.html »</TD></TR><TR><TD CLASS="quote">
Fuel Injector Connector With Pins - Neon
Neon style Fuel Injector connector with uncrimped pins
(Fits Bosch EV6 style injectors)
Includes one connector and three uncrimped pins (one extra just in case)
$8.00
$8.00
That pic above does NOT look the same.
RSX injector, RSX injector clip, RDX injector clip:
RDX injector + clip:
More RDX clips:
Toyota/RDX Compatable clip and RDX Injector connector
*Fixed pic link*
Pirate
Modified by PirateMcFred at 12:30 PM 1/22/2008
More RDX clips:
*Fixed pic link*
Pirate
