Need help with o2 sensor
Old Apr 25, 2007 | 07:05 AM
hinds90's Avatar
Default Need help with o2 sensor
I have a 96 civic with a d16z6 header and down pipe. I have 2 o2 sensors on my 96 dx but the header only has one o2 sensor hole. I am going to get another bunge welded to the down pipe does it matter were it gets welded or does it need to be in a certain place. Also does 1 of the 2 o2 sensor have to go before the other or it doesn't matter.
Old Apr 25, 2007 | 07:36 AM
f_l_g's Avatar
Default Re: Need help with o2 sensor (hinds90)
yes it does matter where they go. The primary or the 1 on the header regulates a/f ratio before the cat and the secondary should be fitted right after the cat because they regulate each other. i have been dealing with this 02 problem for while. Correct me if i'm wrong though.
Old Apr 25, 2007 | 05:41 PM
hinds90's Avatar
Default Re: Need help with o2 sensor (f_l_g)
How do you tell which goes where. I know the wire on the female end of each connectors are different colors. Also I don't have a cat on the car the header eliminated it. I was thinking about putting the o2 sensor at the end of the down pipe buy the shiftlinkage.
ramboPandA
Sep 16, 2015 04:57 PM
WIb16crxWI
May 18, 2006 07:18 PM
acc97lxAndy
Jul 16, 2004 03:20 PM
colombian linx
Feb 3, 2004 08:57 AM
quik2kSi
Sep 22, 2002 07:08 PM
