Timing belt
Old Apr 25, 2007 | 06:14 AM
Stuartz's Avatar
Default Timing belt
Just wondering if when fitting a timing belt , is there a pre tensioner (manual) when fitting the belt before the auto tension takes affect
Old Apr 25, 2007 | 06:23 PM
preludefien
Guest
Posts: n/a
Default Re: Timing belt (Stuartz)
someone correct me if im wrong but i dont think so...
Old Apr 25, 2007 | 06:25 PM
rudelude79's Avatar
NO JUST LEAVE THE LOOSE SIDE OF THE BELT TO THE TENSIONER SIDE BEFORE RELEASING THE TENSIONER AND YOU SHOULD BE FINE
Old Apr 25, 2007 | 09:31 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stuartz &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if when fitting a timing belt , is there a pre tensioner (manual) when fitting the belt before the auto tension takes affect </TD></TR></TABLE>
No. You have either a manual tensioner (H23) or auto tensioner (H22), but not both.
Old May 1, 2007 | 03:16 AM
Stuartz's Avatar
How tight should the belt be when the tensioner is realesed mine isnt very tight ? is this wrong ?
Old May 1, 2007 | 07:48 AM
Hawkze_2.3's Avatar
Default Re: (Stuartz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stuartz &raquo;</TD></TR><TR><TD CLASS="quote">How tight should the belt be when the tensioner is realesed mine isnt very tight ? is this wrong ?</TD></TR></TABLE>
It may be a bit loose on the 'long' side (crank up to the exhaust cam gear), but if you can turn it over by hand multiple times and the timing stays good, you should be fine.
f20beme
Apr 8, 2015 07:47 PM
drbenne
Nov 19, 2007 01:39 AM
Benhawk
Jan 29, 2007 11:49 AM
accordredliner
Jun 15, 2005 10:21 AM
OzWolfbane
Jan 7, 2005 05:14 PM
