Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
k series throttle body on d17 intake manifold
Old Apr 25, 2007 | 01:45 AM
Change Me's Avatar
Default k series throttle body on d17 intake manifold
i heard that it bolts on and all u need is an adapter... what do u guys think??
Old Apr 25, 2007 | 04:07 AM
toyomatt84's Avatar
Sanji
You could probably fit any throttle body with the right adapter. I'd say it's not worth it at all, considering the fact that it won't produce noticeable results.
Old Apr 25, 2007 | 07:46 PM
Boilermaker1's Avatar
Default Re: k series throttle body on d17 intake manifold (EM2*****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2***** &raquo;</TD></TR><TR><TD CLASS="quote">i heard that it bolts on and all u need is an adapter... what do u guys think?? </TD></TR></TABLE>
If it needs an adapter, then it doesnt "bolt on". Besides, I dont see the point... you cant port out the hole in the manfold without making a mess.
Old Apr 27, 2007 | 12:51 AM
Change Me's Avatar
Default Re: k series throttle body on d17 intake manifold (Boilermaker1)
ummm....im gonna be nice on this one.. i meant the adapter so u can run an intake on it.. ddurrrr cuz the k series throttle body is twice as wide as the d series...
Old Apr 27, 2007 | 10:54 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2***** &raquo;</TD></TR><TR><TD CLASS="quote">ummm....im gonna be nice on this one.. i meant the adapter so u can run an intake on it.. ddurrrr cuz the k series throttle body is twice as wide as the d series...</TD></TR></TABLE>
I'm a tad confused here. You want to run a DC5 throttle body, on the D17's intake manifold? So, you can use a DC5's intake, or just a larger tubing intake?
Regardless, throwing more flow into the equation won't help your D17 perform better. As is, it's not requiring more flow on the intake side, as much as it's requiring better cams to put more air in the cylinders. To be honest, increasing the air volume by that much, will probably hurt you a lot more than help you.
Old Apr 27, 2007 | 11:08 AM
jivi's Avatar
Default Re: k series throttle body on d17 intake manifold (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless, throwing more flow into the equation won't help your D17 perform better. As is, it's not requiring more flow on the intake side, as much as it's requiring better cams to put more air in the cylinders. To be honest, increasing the air volume by that much, will probably hurt you a lot more than help you.</TD></TR></TABLE>
Agree with toyomatt
That's what they called AF(air fuel) mixture.
mrbsponge
Aug 19, 2008 08:19 AM
mesonerz
Apr 11, 2008 06:38 PM
LoW ToNE
Dec 11, 2007 04:54 PM
JDM_EK4_Coupe
Mar 12, 2007 12:29 PM
1990hondaHF
15
Apr 5, 2004 10:37 PM
