mustang throttle body
normal mustang tb are 70-75mm which is huge for a honda. You can get them from bbk pretty cheap. Professional products also has some cheap that work well for na.
i have been wondetring about this... is there a write up somewhere? what year tb works? is it the '99ish and up 4.6 or the old 5.0 one to use? i only have a couple of more things to get for my motor and it will be ready and the tb is one of those things...
i believe the 91 and up all from ford work. there wouldnt be any reason to go and get a 70mm tb for a mustang since you can get one with the same size tb for a honda bolt pattern. if you go mustang go big, 90mm+
yes but there cheaper in proce..a 70mm is like $189.99.what honda 70mm is that cheap..
Also how does it bolt up do the hols lign up the same..
you have to purchase a tb plate as well, imo with the fab work and changes that need to be made, you will end up spending more then its worth, i know camp1320 sells billet honda tb's for awesome prices.
accufab 90mm tb $250
tb plate $40,
tps sensor $75,
custom tb linkage 40,
cut and weld new tb plate $80.00
total invested $485.00
edit: vband 60.00
545.00 i shouldve just bought a tb from tom
i think 275 sounds pretty good to me
tb plate $40,
tps sensor $75,
edit: vband 60.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks »</TD></TR><TR><TD CLASS="quote">accufab 90mm tb $250
tb plate $40,
tps sensor $75,
I was just gonna give the same breakdown. I have about $350 invested into getting my 75mm Mustang TB to work.
tb plate $40,
tps sensor $75,
hey guys sorry been busy with work and race season.. NO MOD NECESSARY DIRECT BOLT ON.. JUST NEED TO MATCH PORT THE MANIFOLD
WE STOCK AND CARRY 70,72,74,76,78MM ALL IN STOCK
where can we find this at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks »</TD></TR><TR><TD CLASS="quote">i believe the 91 and up all from ford work. there wouldnt be any reason to go and get a 70mm tb for a mustang since you can get one with the same size tb for a honda bolt pattern. if you go mustang go big, 90mm+
yes im thinking about 90mm t/b
thanksguys for all the info
keep it comin
Modified by sa90eg at 3:07 PM 4/26/2007
keep it comin
Yup.. The upgraded shaft is key.. I haven't had any issues with them..
All others will break. Or the little bolts holding the throttle blade come off.
Loctite them!!
Loctite them!!
Accufab, free shipping:
http://www.jdsperformance.com/...ake=0
The MAC one is also supposedly a decent piece.
