DIY red/white taillights for DA lovers
Old Apr 24, 2007 | 11:11 AM
deadline's Avatar
Default DIY red/white taillights for DA lovers
got info from: http://www.g2ic.com/forums/showthread.php?t=161466
okay i've been searching around to find out who makes these taillights for DA's and to find out the were homemade....nice...
so i just posted this up for all DA lovers to know how to do it..
Clearing my tails.
I first started with the CASTROL superclean on the 90-91 tails. Sure they look great... until comparing them to G2IC member waramp's modified clear after-market tails.
I even tinted my supercleaned 90-91 tails to give them a dark cherry red look but still didn't give me what I wanted. I didn't like the look of the faded white look the tail was giving me... but wanted them to look "clear". After searching, I found info on modified 92-93 tails. They looked identical to waramp's tails so I decided to get right to it.
So I started with a set of damaged 90-91 tails using a heat gun I purchased at crappy tire for $20 to practice and test my heat gun.
Sure, this thing worked great... but took a bit of time.
I have modified my 98 RAV4 tails on 2 separate occasions using the oven method, so you can say I have considerable experience in terms of baking the lights... but I wanted to make use of my new toy I just bought.
So after quite some time, I finally got this apart. My first thing I got a hold of was the white strip with the pink lines. This thing was so sensitive to anything touching it, I could just rub the pink off with my fingers. So I kept rubbing them with a cloth until they turned white. Some of the white I noticed were gray. I thought I wasn't rubbing enough so I continued until it turned black. **that's when I noticed with the superclean method people vent about when their lines turn black... they did too much to it**. I thought it was grey because I didn't get the pink enough, but it was the opposite...
I think the pink lines were probably a darker RED originally... so this is what happens to the lines...
Red -> Pink -> white -> gray -> black -> clear.
I used a 2000 grit sandpaper to get the rest of the white to appear black.
Then I thought... hmmm... maybe I can dismantle my other set of 90-91 damaged tails (ya, I have a few of them laying around...), do this, and add the plastic piece to my 92-93 tails. I like the look of the 92-93 tails more than the 90-91. I don't really like the look of the white part to look strong as I have a black car... so I think this would blend in with the car more.So after some time and patience, this is what your plastic piece can look like. This can take 5-10 minutes - depending on how detailed you want the black stripe to look. I also tried to rub superclean on the stripe directly with a cloth. It removed a lot of the red/pink but struggled with the white to black. I strongly suggest you use 2000 grit wet/dry sandpaper and wet sand this down.
when your done:
I used 2000 Grit sandpaper (1500 works too, but won't look as smooth as the 2000) and carefully and lightly wet sanded until I got rid of all the red/white. The edges and corners are VERY tough... if the edges seem to be taking a while, its not just you. It took me much longer. When I was doing this on my practice set, the lines were damaged - they had knicks, and the stripes were ruined. If your lines have surface damage, this modification will not be 100% successful, so when taking the lights apart be VERY careful not to damage the plastic piece with the lines. I forced the practice set apart cracking the lens and damaged the plastic piece on my practice set.
Old Apr 24, 2007 | 11:40 AM
TEXN3's Avatar
Default Re: DIY red/white taillights for DA lovers (deadline)
Old news...and I think this would belong in the Tech section.
Still a great mod...I miss my DA at times. Great little commuter car.
Modified by TEXN3 at 1:00 PM 4/24/2007
Old Apr 24, 2007 | 11:57 AM
Phil DeVtec's Avatar
Default Re: DIY red/white taillights for DA lovers (TEXN3)
Old news, but still cool to do nonetheless.
Old Apr 24, 2007 | 12:58 PM
deadline's Avatar
i wuz searching for it in H-T but couldnt find it here so i just revamped it
Old Apr 24, 2007 | 02:12 PM
Agent_EM1's Avatar
Default Re: (deadline)
Thanks! Good info
Old Apr 24, 2007 | 08:10 PM
deadline's Avatar
Default Re: DIY red/white taillights for DA lovers (Phil DeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec &raquo;</TD></TR><TR><TD CLASS="quote">Old news, but still cool to do nonetheless.</TD></TR></TABLE>
deadline's Avatar
Default Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks! Good info </TD></TR></TABLE>
Old Apr 25, 2007 | 07:48 AM
gen2_4door's Avatar
I did this a few years ago with my 90-91 DB1 taillights. I left the lines grey so if gave them a sort of tinted look. Here's a couple old pics of them.
And yes i know my plates are showing on the first pic, but they're old plates anyways. And the rear end is much cleaner now too no more emblems either!!
Old Apr 25, 2007 | 07:58 AM
deadline's Avatar
Default Re: (gen2_4door)
^^ nice..........
crvtt717
27
Jul 11, 2011 06:21 AM
davidluko
Aug 18, 2006 09:32 AM
ZaxEG
Jul 21, 2003 07:43 PM
builtB20turbo
Sep 23, 2002 05:40 PM
muskrat
May 10, 2002 06:25 AM
