FS: '94 Vigor GS Perfect Beater/Daily Driver Southern California
1994 Acura Vigor GS for sale.
VIN: JH4CC2562RC0039xx (Clean Title)
4-door. I've had the car since 145,000 miles and I am now looking to sell it.
Facts:
2.5L 5-cylinder engine with 206,xxx miles
5-speed manual transmission
Color: Dark purple/Wine with beige leather interior
*All parts were replaced with OEM Honda unless noted otherwise*
Engine
Timing belt/water pump and accessory belts changed at 159,000 miles
Distributor cap and rotor changed at 165,000 miles
Oil changed every 5,000 miles with Mobil 1 synthetic + Honda OEM filter until last oil change (see notes)
Transmission/Clutch
Slave cylinder changed at 175,000 miles
Fluid changed at 145,000 and at 190,000 miles
New driver side axle/CV boot at 175,000 miles
Brakes
Master cylinder replaced at 149,000 miles
Right rear caliper replaced at 151,000 miles
New BREMBO rotors and Honda OEM brake pads changed at 186,000 miles
NOTES
1. There is an oil leak around the cam cover/exhaust manifold. I replaced the gaskets, but the leak is still there. So you get a mild smoking effect.
2. The clutch, as far as I know, is original.
3. The 2 front tires are in good shape, the 2 rear tires are almost bald. They are all Bridgestone LS-H, the highest rated tire per tirerack.com.
4. At my last oil change, I switched to Castrol High Mileage.
5. The car will come with an Alpine head unit (CD player) and a Broadway mirror.
Overall, this is a great car. The AC works fine and it has power everything. The car gets about 23 mpg in combined driving, and 27 mpg if you did highway only. It does take premium gasoline, but I've used 89 octane without a problem.
Negatives/Quirks:
1. Oil leak as described above.
2. Driver's window seals like a car with 200,000 miles.
3. Speakers have poor connections (they connect/disconnect often).
4. Rear driver side window can only be controlled by the rear driver side passenger (master control probably has a bad connection).
5. Passenger side CV boot is torn.
6. Paint has fade/oxidation.
7. Driver's seat is torn up (but I do have a seat cover on it).
$2500 OBO. This is a good car. It just needs a little attention. Perfect car to just put oil and gas in it. In the time I've owned the car, I've started a successful business and bought a house because I wasn't concerned with lowering it, dropping in a VTEC swap, or anything else like that. On top of that, no one will want to steal this car. So if you're ready to make that jump, give this car a look.
(626) 590-6828 or PM me.
Pics will be posted later today.
Thanks, H-T!!!
Modified by frostwhite_92 at 1:32 AM 4/25/2007
Facts:
Engine
Transmission/Clutch
Brakes
NOTES
Negatives/Quirks:
Thanks, H-T!!!
94accordsedan
Nov 13, 2007 12:19 PM
94accordsedan
Northeast (Sales)
Nov 13, 2007 12:17 PM
