Tach no working
Old Apr 24, 2007 | 09:54 AM
prelude_93vtec's Avatar
Default Tach no working
hey i have problems with my dash tach. it never works. when it decides to, its always 1000rpm off. EXACTLY 1000rmp off. is my needle busted or something? because i really want it to work. my aftermarket one works but the dash one doesnt. thanks for the help
Old Apr 24, 2007 | 11:43 AM
'95 BA8's Avatar
Default Re: Tach no working (prelude_93vtec)
Just put that big ugly aftermarket one in front of the original one, you're set.
Old Apr 24, 2007 | 07:34 PM
preludefien
Guest
Posts: n/a
Default Re: Tach no working ('95 BA8)
mines did the same thing...it turned out that the signal wire was slit and was touching metal which caused it not to work...maybe you should check your wire to make sure that it is not sliced or anything..
Old Apr 24, 2007 | 10:01 PM
Default Re: Tach no working (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">mines did the same thing...it turned out that the signal wire was slit and was touching metal which caused it not to work...maybe you should check your wire to make sure that it is not sliced or anything..</TD></TR></TABLE>
what was wrong with yours when it did that? was it 1000rpm off and didnt work sometimes?
Old Apr 25, 2007 | 04:38 AM
preludefien
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">
what was wrong with yours when it did that? was it 1000rpm off and didnt work sometimes? </TD></TR></TABLE>
yep
Old Apr 25, 2007 | 04:40 AM
mattsnooz's Avatar
HAHAHAHA NOooooooooooooooo, those things r fugly. the stock dash on preludes is the bomb.
yeah id tend to agree with the above. if its working partially, chances are its getting power occasionally, and is in working order (chances of them failing are very very unlikely, so chances are its the power wire, ground, or the signal wire going to your meter
Old Apr 25, 2007 | 11:02 AM
mgags7's Avatar
Default Re: Tach no working (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">chances of them failing are very very unlikely</TD></TR></TABLE>
wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">so chances are its the power wire, ground, or the signal wire going to your meter</TD></TR></TABLE>
uh, no **** sherlock. Here's some actual info: The whole cluster uses the same power and ground, so that isn't it, or the whole thing would be fucked. Its the signal wire.
I hate to be an *** to you, but I really hate it when people make up information and post it like its true.
Old Apr 25, 2007 | 12:04 PM
Default Re: Tach no working (mgags7)
arite thanks. can anyone tell me where i can find the signal wire and where its located?
Old Apr 25, 2007 | 06:19 PM
preludefien
Guest
Posts: n/a
lol thanks matt i was right...which signal wire do you mean...the one for the stock tach.
Old Apr 25, 2007 | 06:57 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">lol thanks matt i was right...which signal wire do you mean...the one for the stock tach.</TD></TR></TABLE>
yeah dude
Old Apr 25, 2007 | 08:16 PM
where can i find this wire?
Old Apr 26, 2007 | 04:29 AM
marks_lude's Avatar
ive been doin alot of tach research to fix mine. the tach circuit is grounded right under your CEL test pug, to the left of the shift cables. It ground 403.
for detail diagrams, go here
http://www.absoluteprelude.com...23229
its shows alot of great info on how to test ur tach circuit.
Old Apr 26, 2007 | 03:43 PM
where can i find the tach signal wire?
Old Apr 26, 2007 | 04:49 PM
preludefien
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks_lude &raquo;</TD></TR><TR><TD CLASS="quote">ive been doin alot of tach research to fix mine. the tach circuit is grounded right under your CEL test pug, to the left of the shift cables. It ground 403.
its shows alot of great info on how to test ur tach circuit.</TD></TR></TABLE>
is right there...either that or go to a honda dealer and they can give you a print out.
Old Apr 27, 2007 | 03:49 PM
lol im 15 years old and im kinda havin problems with the diagram. does anyone have any pics that they can show me? im tryin to follow the wires but aint finding anything thatnks i appreciate the help
Old Apr 27, 2007 | 04:16 PM
preludefien
Guest
Posts: n/a
lol ok...i would say that i can take pics but its too much to take my dash apartto take pics...didnt you say you have a bolt on tach...
Old Apr 27, 2007 | 05:23 PM
preludefien
Guest
Posts: n/a
dude ill take the pics for you tomorrow..not that big of a deal...
Old Apr 27, 2007 | 05:48 PM
mattsnooz's Avatar
actually i highly doubt you wern't trying to sound like an ***, because frankly u are
and btw, the tachs themself very rarely fail. its wiring usually the problem, not the actualy unit cup cake. they are usually designed for life of car. so if 1 fails per life of 200-300 thousand km's life expectancy means they fail alot, than your expecting way too much. if you never have to replace the tach in your car (which i've never had in all my preludes (which is 3 generations over 8 years) ,than doesn't that mean that they don't really fail that often?) odometer sticks once and a while but the unit itself is solid
Old Apr 27, 2007 | 07:54 PM
ya im sorry for all the troubles i jus took apart the whole dash today but there was only one problem. i didnt know what i was lookin for lol. when i friest start the car, the tach works but its exactly 1000rpm off and after a min or so its jus way off all the time
Old Apr 27, 2007 | 07:56 PM
o ya my bolt on tach got stolen and i always loved the one onn the dash and would really like to get it workin again
Old Apr 28, 2007 | 11:02 AM
man today the tach was barely moving at all. i still dont know the problem.
Old Apr 29, 2007 | 09:46 AM
Old Apr 29, 2007 | 01:04 PM
bluedlude's Avatar
keep looking. like matt was saying, they share the same power and grounds but have different signal wires. if you look at the wiring going to the guages compare the coloring from guage to guage. grounds and powers will have the same base colors on the wiring and the signal wire should be different all together. then you'll have to trace that and see why its getting interupted. or you can use a multimeter after you pull some wire back and find the constant source and the signal.
Old Apr 29, 2007 | 01:35 PM
Default Re: Tach no working (bluedlude)
but i have no idea where this signal wire is i cant find it anywhere
Old Apr 29, 2007 | 04:18 PM
bluedlude's Avatar
do you know which wires are going to your tach? is it 2 or 3 wire? start with that. i dont have a fourth gen, so i dont know if all the wiring would be the same.
it could still just be a ground too man...
