spoon brake calipers and rotors
im interested in buying either spoon calipers or both calipers and rotors but i haven't been able to find a site selling them for our cars, em2s. any info? thanks
oh good point. no **** about the price. lol. i calculated $2250 shipped. god damn. i was expecting 1500. looks like im going with stop tech or willwood. thanks.
There ya go...
https://honda-tech.com/zerothread?id=1978145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synapz »</TD></TR><TR><TD CLASS="quote">^^
will NOT fit.
It's for s2ks, rsx-s, and etc with bigger OEM rotors.
will not fit em2/ep3.</TD></TR></TABLE>
Those are the ONLY calipers spoon makes that will work. Twin blocks won't fit dude.
will NOT fit.
NO!
If you do a 5 bolt conversion, where will you get the S2k spoon calipers to fit?
Stick with 4x100. With the twin block Spoon calipers, you use 11.1" rotors, which can be redrilled to 4x100. With the monoblock Spoon calipers, you use the 11.8" rootrs, which can be redrilled to 4x100. These 11.8" rotors may not fit the 5x114.3 hub.
Either application will fit any 01-05 Civic (except 04-05 Si.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">NO!
Either application will fit any 01-05 Civic (except 04-05 Si.)</TD></TR></TABLE>
If he did the 5 lug conversion, the calipers would bolt right in. See, the 5 lug would be from a DC5, which shares the same mounting structure for the calipers and similar rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">Assuming the hub (and I guess knuckle?) is from a DC5. I'm not an EM2/DC5 expert</TD></TR></TABLE>
Yeah, if you wanted to go with a 5 lug setup, the whole assembly would be from a DC5 (or possibly a late model EP3, due to it's the same hub/knuckle).
The twin block calipers will not bolt up to EP3/DC5 knuckles or the EM2 knuckles for that matter. HE HAS TO USE THE MONOBLOCK CALIPERS with an EP3/DC5 knuckle! That is unless he gets some custom brackets made.
Go to http://www.SpoonSports.us or http://www.OpakRacing.com and let them know Roxspin sent you for Spoon and JDM stuff.
No he doesnt, who told you that?
At most, he'd need a custom rotor. However, the RSX base has VERY similar to front ITR brakes to the point that you could bolt the spoon twin block caiper on those knuckles. Whether or not you can use the stock rotor I don't know, the height may be off, but the caliper will clear the 11.1" rotor.
Rboosted717
Sep 24, 2001 03:43 PM
