Cracked OEM side skirt
Old Apr 23, 2007 | 09:38 PM
wowpaw's Avatar
Default Cracked OEM side skirt
Hey guys, I was just wondering if anyone in the bay area knows a good place to fix a cracked side skirt? It hit a speedbump and cracked on impact, and actually came off a bit from the car. Any help would be appreciated, thanks
Old Apr 23, 2007 | 10:25 PM
haiyter's Avatar
ever heard of bondo
Old Apr 24, 2007 | 12:50 PM
wowpaw's Avatar
Default Re: (haiyter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haiyter &raquo;</TD></TR><TR><TD CLASS="quote">ever heard of bondo</TD></TR></TABLE>
Any other suggestions?
Old Apr 24, 2007 | 01:12 PM
Twistedframe's Avatar
Default Re: (wowpaw)
Either get another one from ebay or a junk yard, -OR- just try and fix the cracked one by removing from the car and turning it over, scratching the hell out of the plastic (really making some deep groves in it going in different directions) and then apply fiberglass resin and a few strips of glass over it. If the scratches aren't deep enough to make the surface extremely rough, then the resin will let go after a short period of time. I fixed a front bumper cover like this and it seemed to hold really well.
Old Apr 24, 2007 | 01:36 PM
wowpaw's Avatar
Default Re: (Twistedframe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twistedframe &raquo;</TD></TR><TR><TD CLASS="quote">Either get another one from ebay or a junk yard, -OR- just try and fix the cracked one by removing from the car and turning it over, scratching the hell out of the plastic (really making some deep groves in it going in different directions) and then apply fiberglass resin and a few strips of glass over it. If the scratches aren't deep enough to make the surface extremely rough, then the resin will let go after a short period of time. I fixed a front bumper cover like this and it seemed to hold really well. </TD></TR></TABLE>
After taking a closer look, I think it might be easier if I replace it completely. The crack is pretty deep (also pretty scratched up) and I'm sure it would take alot of work to try and fix this.
Anyone got a good side skirt seller on ebay? Ive checked HandAAccessories but am going to try and use that as a last option because of the price.
Old Apr 24, 2007 | 05:05 PM
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wowpaw &raquo;</TD></TR><TR><TD CLASS="quote">Any other suggestions?</TD></TR></TABLE>
junkyard.
Old Apr 24, 2007 | 09:54 PM
SuShiBoiiii's Avatar
Default Re: (accordcd_7)
im going to take a chance and say that this isnt a stock side skirt...but if it isnt im sure you can find something at the local junkyard...and since your in the bay area check out pick n pull in sj or import center in hayward
Old Apr 25, 2007 | 10:54 AM
wowpaw's Avatar
Default Re: (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">im going to take a chance and say that this isnt a stock side skirt...but if it isnt im sure you can find something at the local junkyard...and since your in the bay area check out pick n pull in sj or import center in hayward </TD></TR></TABLE>
Yes, it is the OEM one.
Thanks for the suggestions
Sleepy_Red_hatch
Dec 22, 2005 03:24 PM
khang77642
Mar 10, 2005 08:07 PM
Snail Tuning
Feb 17, 2004 08:07 AM
tko21
Jun 14, 2003 05:30 PM
J.A.SBTCC
May 27, 2003 12:15 AM
