b18a swap questions really quick before it goes in
Old Apr 23, 2007 | 09:28 PM
tdizz07's Avatar
Default b18a swap questions really quick before it goes in
okay i have the b18a block and head, with the 94+ dizzy, 94+ intake manifold, stock injectors out of my 95 ex, the t/b and stuff like that. my question is are there any connections/plugs i need to worry about?
Old Apr 24, 2007 | 05:55 AM
LS-V Turbo's Avatar
Default Re: b18a swap questions really quick before it goes in (tdizz07)
i think all of the connectors are the same as long as you don't switch to vtec. but why run single cam tb and injectors? maybe you know something i don't let me know.
Old Apr 24, 2007 | 06:53 AM
Tomdata's Avatar
Default Re: b18a swap questions really quick before it goes in (LS-V Turbo)
the single cam throttle body is a bit small. single cam injectors are the same as b-series injectors. Everything should plug right in and bolt right up with no problems, as long as you have integra mounts, tranny, shift linkage and axles.
Old Apr 24, 2007 | 01:03 PM
tdizz07's Avatar
Default Re: b18a swap questions really quick before it goes in (Tomdata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata &raquo;</TD></TR><TR><TD CLASS="quote">the single cam throttle body is a bit small. single cam injectors are the same as b-series injectors. Everything should plug right in and bolt right up with no problems, as long as you have integra mounts, tranny, shift linkage and axles.</TD></TR></TABLE>
sweet i got all that stuff, cuz i kno the back of the block looks a little different than a obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-V Turbo &raquo;</TD></TR><TR><TD CLASS="quote">i think all of the connectors are the same as long as you don't switch to vtec. but why run single cam tb and injectors? maybe you know something i don't let me know.</TD></TR></TABLE>
yeah, the injectors are the same size but im just running that tb becasue i dnt have a obd1 teg t/b. i just wanted to get it on and running i was gonna swap it later
Guam_CiviC619
Apr 25, 2009 07:55 AM
MopdiT
Feb 22, 2008 08:10 PM
DOHCgarage919
Oct 8, 2007 08:24 PM
srg
Jun 4, 2006 01:01 AM
tmkpres
Apr 20, 2006 06:46 AM
