SOHC turbo. Hondata Wont rev over 3000 NO BOOST?
Old Apr 23, 2007 | 04:24 PM
jdm_jeners's Avatar
Default SOHC turbo. Hondata Wont rev over 3000 NO BOOST?
I built a Z6 bottom end with Y8 head Turbo. I installed a Hondata S200 and everytime I rev it doesnt pass 3000 rpm and it never boost. What can cause this?
Old Apr 23, 2007 | 04:34 PM
Lord Milferdeen's Avatar
Default Re: SOHC turbo. Hondata Wont rev over 3000 NO BOOST? (jdm_jeners)
Stuck in launch mode perhaps?
Old Apr 23, 2007 | 04:43 PM
Turbo_y8's Avatar
Default Re: SOHC turbo. Hondata Wont rev over 3000 NO BOOST? (Lord Milferdeen)
yea, id say that sounds like 2 step, without antilag.
Old Apr 23, 2007 | 04:44 PM
Turbo_y8's Avatar
Default Re: SOHC turbo. Hondata Wont rev over 3000 NO BOOST? (Turbo_y8)
it does run and drive normal though, right?
if you just crusiing along, and you push the clutch in or throw it in neutral itll rev higher?
Old Apr 23, 2007 | 05:03 PM
Luserkid's Avatar
Sounds like it needs a tune.
Old Apr 23, 2007 | 05:55 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">yea, id say that sounds like 2 step, without antilag.</TD></TR></TABLE>
I agree...who did your ecu?
Do you know if a 2-step launch control was put in?
Old Apr 23, 2007 | 06:24 PM
egmatt93's Avatar
Default Re: SOHC turbo. Hondata Wont rev over 3000 NO BOOST? (1995Civic)
i had the same problem like 3 days ago, my vss wasnt working so my car though i was stopped, so every time i hit 4k rpm's i would bounce off 2 step...
edit: i fixed the vss and everything is fine now. does ur spedo work?
ACrite3404
Dec 20, 2007 07:36 PM
94c1v1cex
Sep 30, 2007 06:35 PM
playahwitgame
Nov 19, 2006 07:10 PM
Pat
Dec 13, 2002 03:40 PM
