how do i calculate tubing weight by specific weight and wall thickness.
Old Apr 23, 2007 | 01:41 PM
RACEPAK's Avatar
Default how do i calculate tubing weight by specific weight and wall thickness.
hello everyone.
so im not very bright. but i need to make some calculations anyway.
lets say i need to know the weight of 3.28ft (1meter) tube, and the only values that i have are specific weight/gravity and wall thickness ,
thanks for any help
p.s
anyone know the specific weight of 304 and 321.
Old Apr 23, 2007 | 02:37 PM
dfoxengr's Avatar
Default Re: how do i calculate tubing weight by specific weight and wall thickness. (RACEPAK)
you only need to look up the density of the material.
use matweb.com, wikipedia.org, or google.
if you do only have the sp. wt. then divide it by gravity, as the sp.wt=gravity*density
so youd most likely divide by 9.81 m/s^2 to get something in the units of kg/m^3
then multiply the volume of the tube.
vol=pi*[(od/2)^2-(id/2)^2]*length
specific gravity is a ratio of the density of your material divided by the density of water.
for you, multiply the value of your materials specific gravity (unitless) by 1000 kg/m^3 and youll have your material's density. then follow instructions above.
Old Apr 23, 2007 | 07:54 PM
Orangecivic251's Avatar
Default Re: how do i calculate tubing weight by specific weight and wall thickness. (dfoxengr)
what he said!^^^^^^^
Old Apr 24, 2007 | 03:06 AM
dfoxengr's Avatar
Default Re: how do i calculate tubing weight by specific weight and wall thickness. (HondaEMS.com)
good post lol
larrybk032
Honda Motorcycles
Jul 20, 2011 04:47 PM
allmotorhonda
Jan 2, 2003 04:55 PM
Apocalypse
Nov 8, 2002 04:45 AM
