Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Clutch and flywheel for my ES
Old Apr 23, 2007 | 10:26 AM
jivi's Avatar
Default Clutch and flywheel for my ES
Well as i'm going to change my engine we found out also the clutch is already damaged.
I need your recommendation guys if I go for Honda parts(OEM) or get the aftermarket one like exeddy, ACT etc.
what is the pros and cons of lightweight flywheel?
Old Apr 23, 2007 | 01:57 PM
toyomatt84's Avatar
Sanji
Well, the lighter the flywheel is, the easier it is for an engine to react to throttle increases, so it'd be like a more responsive throttle. But, going too light will start to kill off your torque, and there's not much there to begin with. I wouldn't go lighter than 11.0lbs on the flywheel. As far as clutches go, you won't need anything past a stage 2, even under the most abusive conditions. I would say OEM replacement, or maybe a step higher. Anything more, and it'll be annoying.
Old Apr 23, 2007 | 06:17 PM
katzenjammer84's Avatar
+1 agreed with toyomatt84
As for companies, I've always liked Fidanza's flywheels and ACT makes a mean clutch, but I guess they all have something to offer.
redline760
Apr 10, 2009 06:35 AM
fullthrottleking
Aug 1, 2008 08:47 PM
93sivtec
Apr 22, 2007 08:57 AM
IntegraMastaz
Dec 13, 2005 05:26 AM
