Toshiba Satellite A65-S1062 2.6GHZ Celeron, 512MB, 40GB, DVD/CDRW, XP Home
Old Apr 23, 2007 | 09:13 AM
typet's Avatar
Default Toshiba Satellite A65-S1062 2.6GHZ Celeron, 512MB, 40GB, DVD/CDRW, XP Home
****SOLD****
Have this laptop for sale, it is about 2 years old and is in good operating condition. This will include all the original boxes, wireless pc card and oem stuff. Only used the battery 2x, removed from notebook and it is like brand new. Computer will be freshly installed with the reinstallation disk. Asking for $320 plus shipping and 3% paypal fees. Great for a student on a budget...
Here are the specs:
Toshiba A65-S1062 Satellite Notebook PC
Intel Celeron Processor at 2.60GHz; 512MB of Main Memory (Expandable to 2048MB); 40GB hard disk drives; DVD-ROM/CDRW multi-function drive; Microsoft Windows XP Home
Specifications:
CPU: Intel Celeron processor at 2.60GHz
L2 Cache: 128KB Level 2 cache memory integrated on die
400MHz Processor System Bus Clock Speed
Memory: 512MB (2 DIMM) expandable to 2048MB (Both slots may be occupied)
Expansion memory: 128MB/256MB/512/1028MB, SODIMM, PC2100 DDR266
Screen size: 15”
Data/Address Bus Width: 64bit/32bit
Intel 852GME Chipset
Primary Hard Disk Drive: 40GB hard disk drive, Enhanced IDE (ATA-5) interface, 4200rpm drive rotation; 9.5mm height, 0.2lbs, Service Removable
DVD-ROM/CDRW Multi-function Drive: Enhanced IDE (ATAPI) Interface; Maximum speed: CDR(
24x), CD-RW(10x), CD-ROM(24x), DVD-ROM(8x); Compatibility: CD-ROM, CD-R (read/write), CDRW (read/re-write), DVD-ROM, DVD-R (read only), DVD-RW (read only), DVD-RAM (read only); Service removable
Software Decoder: InterVideo (Win-DVD 4) - w/SRS Technology
Graphics/Video
15.0" TFT active-matrix display; internal display supports up to 16M colors at 1024 x 768
Intel 852GME Integrated graphics controller; 32MB DDR SDRAM (UMA)
Direct 3D support and DirectVideo
External Color Support/Refresh rate:
640 x 480: 60/75/85/100Hz Non-Interlaced @16M
800 x 600; 60/75/85/100Hz Non-Interlaced @16M
1024 x 768; 60/75/85/100Hz Non-Interlaced @16M
1280 x 1024; 60/75/85/100Hz Non-Interlaced @16M
1600 x 1200; 60/75/85Hz Non-Interlaced @16M
1920 x 1440; 60/Hz Non-Interlaced @16M
Keyboard: Full sized 85 keys with 12 function keys, 2.7mm key stroke, 6mm height; Dedicated Windows. keys support; HotKey function; TouchPad pointing device
Expandability:
2 Memory slots Both slots may be occupied
1 PC Card slot support 1 Type II PC Card
Communications
Integrated V.92/56K modem; Data and fax support
Due to FCC limitations, speeds of 53kbps are the maximum permissible transmission rates during
Download. Actual data transmission speeds will vary depending on line conditions.
Integrated 10/100 Ethernet LAN
Ports
ECP parallel printer port; RGB (monitor) port; 4 Universal Serial Bus ports (USB)
RJ-45 LAN Port; RJ-11 modem port
Dimensions (LxWxH): 13.2 x 11.7 x 1.9
Weight: 7.7lbs
LED Indicators: Power, Power Save Mode, HDD, CD/DVD-ROM, DC-IN, Caps Lock, Arrow, Numeric, Main Battery Charging Status, System Sleep / Suspend status
Analog Devices AD1981B Codec Chip; Software Sound
Built-in stereo speakers; Sound Volume (by dial), Direct 3D Sound (supported by driver), DirectSound (supported by driver) and DirectMusic (supported by driver); MIDI Support; Sound Volume (by Dial); Full Duplex Support
Ports: External Microphone port, headphone port
AC Adapter: 120W external AC Adapter, 100-240V / 50-60Hz frequency (Universal) input voltage, 15V x 8A Output.
Battery Pack: 12-cell, rechargeable, removable Lithium Ion (Li-Ion) battery, 8400mAh
Battery life (main batt): 2.9H
Operating System: Microsoft. Windows XP Home pre-installed
pic 1
pic 2
pic 3
pic 4
pic 5
pic 6
Modified by typet at 10:44 AM 4/28/2007
Old Apr 27, 2007 | 08:10 AM
typet's Avatar
Default Re: Toshiba Satellite A65-S1062 2.6GHZ Celeron, 512MB, 40GB, DVD/CDRW, XP Home (typet)
TGIF bump...
. M i c h a e l
Northeast (Sales)
Feb 27, 2012 02:08 PM
. M i c h a e l
OneSickJDMBB6
Sep 15, 2009 11:36 AM
