Sand blasting safe for rims?
Old Apr 23, 2007 | 08:42 AM
invisible's Avatar
Default Sand blasting safe for rims?
Will sand blasting rims be too much and possiably damage the wheel? Need to strip my wheels but nothing seems to work.
Old Apr 23, 2007 | 08:44 AM
Baggy Spandex's Avatar
Default Re: Sand blasting safe for rims? (cheesee)
If its powdercoat or a forged aluminum rim, it will pit the aluminum if you're not careful. I would strip it chemically if I were you.
Old Apr 23, 2007 | 08:46 AM
invisible's Avatar
Default Re: Sand blasting safe for rims? (NAisBEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">If its powdercoat or a forged aluminum rim, it will pit the aluminum if you're not careful. I would strip it chemically if I were you.</TD></TR></TABLE>
Yeah that's what I was thinking. I already tried Aircraft stuff but didn't do too much...
Old Apr 23, 2007 | 08:48 AM
UCLA.lion's Avatar
I <3 My CB7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that's what I was thinking. I already tried Aircraft stuff but didn't do too much...</TD></TR></TABLE>
you need like 1 can or more for 1 rim, and some elbow grease with some steel wool
Old Apr 23, 2007 | 08:52 AM
invisible's Avatar
Default Re: Sand blasting safe for rims? (UCLA.lion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCLA.lion &raquo;</TD></TR><TR><TD CLASS="quote">
you need like 1 can or more for 1 rim, and some elbow grease with some steel wool</TD></TR></TABLE>
im on my 3rd can. would steel wool be ruff on the rim once the coat is off?
Old Apr 23, 2007 | 08:53 AM
im on my 3rd can. would steel wool be ruff on the rim once the coat is off?</TD></TR></TABLE>Talk to your local powdercoater. They might dip rims in a chemical to strip them, if not, im sure they know someone who does.
Old Apr 23, 2007 | 08:56 AM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">Talk to your local powdercoater. They might dip rims in a chemical to strip them, if not, im sure they know someone who does. </TD></TR></TABLE>
I talked to one and he said they acid dip for powder coated rims. But $50-60 a wheel just to strip them, and I think that's how much it cost to powder coat it also lol...
Old Apr 23, 2007 | 09:51 AM
ek_s2k's Avatar
i had my rims sandblasted and payed 40 bucks for 4 rims,its pretty clean now coz i tried to do it myself using aircraft which is pain when taking off the paint on the small sides.
Old Apr 23, 2007 | 11:12 AM
invisible's Avatar
Default Re: (ek_s2k)
humm anyone else had experience?
Old Apr 23, 2007 | 11:26 AM
nathanong87's Avatar
Default Re: (cheesee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee &raquo;</TD></TR><TR><TD CLASS="quote">humm anyone else had experience?</TD></TR></TABLE>
i JUST got done stripping my RGs.... here is the method i used.... 3 cans of aircraft stripper for all 4 wheels....after you let the stripper sit for 5-10 minutes, use a medium coarse steel wool pad and rub the surfaces of your wheels. repeat until satisfied pretty much.
it depends on how bare u want your wheels. since i primed them myself i just needed to take off the original clear and most layers, but i didn't care if it went to the bare metal or not
Old Apr 23, 2007 | 11:43 AM
invisible's Avatar
Default Re: (nathanong87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 &raquo;</TD></TR><TR><TD CLASS="quote">
it depends on how bare u want your wheels. since i primed them myself i just needed to take off the original clear and most layers, but i didn't care if it went to the bare metal or not</TD></TR></TABLE>
well i need all the way off i guess cuz the paint or poweder coat is kinda thick so if i dont get it all the way off it'll show.
Old Apr 23, 2007 | 12:30 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
ive been having the same problem. i used 2 cans and plastic spatula and scotch bright. still leaves some white stuff. sandblasters in my area say they dont blast aluminum.
Old Apr 23, 2007 | 02:28 PM
well i need all the way off i guess cuz the paint or poweder coat is kinda thick so if i dont get it all the way off it'll show.</TD></TR></TABLE>
just sand them smooth imho that's all u need to worry about
Old Apr 23, 2007 | 02:48 PM
simonsays's Avatar
New User
Sandblasted my LS wheels awhile back. Works perfect
Rikaro
Mar 12, 2008 04:09 PM
bbyass
Feb 27, 2008 04:32 PM
ektouge88
Feb 12, 2006 10:49 PM
teamvirus
Jan 10, 2006 01:13 PM
whoobeedoobee
Sep 16, 2003 04:04 AM
