random parts for sale, obd2b SI ecu plugs...
I've got some things for sale in my garage. i've also got brembo drilled and slotted rotors with hawk brake pads if interested, used for about 7000 miles but still has plenty of wear left. theyre for a civic dx, i can also give you axle hub that goes with it as well as calipers.
OBD2B ecu side plugs i got them off an EM1. $40.00
Integra type-r ecu. its obd2A i used on my gsr so i know it works. $250 OBO
civic engine taken out of an 88 civic i'll get the engine code later. ran pretty well when we took it out.
$90.00
timing belt for a d16y7 i dont know if it will work for others. never used! $20
Water pump with new seal for a d16y7 never used! $30.00
AC condenser taken out of a 96 civic the lower hole has a tap screw where the bolt would usually go
$10.00
just PM and we can work out a better price on everything. just need these things gone. I've also got a working ex gauge cluster i'll let it go for $50 i'll put up pics later.
please bump if you view
Modified by 4drgsr96 at 7:02 PM 4/23/2007
civic engine taken out of an 88 civic i'll get the engine code later. ran pretty well when we took it out.$90.00
$10.00just PM and we can work out a better price on everything. just need these things gone. I've also got a working ex gauge cluster i'll let it go for $50 i'll put up pics later.
THANKS i also got a full d16y7 with tranny! 150 bux if interested. working well when i pulled it out. pics up later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ColMustard »</TD></TR><TR><TD CLASS="quote">Bump for fellow HD Pep
come on people!!! i know theres people on here rolling on y7s! spring maintanance damn it! you guys need a timing belt and water pump!
