b series motor set up
specs are
b18c5 block
darton slee ves bored to 85 mm
ls stroker crank with oil shedding coating
crower rods
ati dampner
tottally worked head
oversized intake valve
both intake and exhaust vavles sunken into the head
massive porting flow bench numbers available to serious buy with proof of funds before that information is given
jun 3 cams, valve springs, retainers,
rev valves
exedy chromoly clutch and flywheel
no pistons and missing a couple of engine seals and bolts
cometic head gasket
hondata intake manifold gasket
intake manifold gasket match for 70mm t.b.
all runnners port matched to cylinder head
motor mounts inlcuded
starter
intermediate shaft
ITR LSD trans, along with ls trans with cracked case
both axles
alternator
engine wiring harnes
water pump
oil pump
spoon magnetic plugs
mugen thermostat
all brackets and mounts
pretty much everything you need for a complete swap minus pistons, t.b. fuel rail, injectors and timing belt stuff.
all desiegn work and machini ng done under strict supervision of MCA Motorsports
i have over 12 grand invested in just the engine. you might not see why, but alot of machining was redone over and over to get measurements perfect.
it took 2 years to get the head to where it is right now. i'll just say it flows more than a trick big block head at 400 lift
[B]I WILL NOT PART IT OUT
SELLING IT AS A WHOLE PACKAGE
ASKING PRICE IS 8 GRAND FOR EVERYTHING
open to offers, trades, swaps, show me what you got
lowballers will be ignored
thanks for your interest.
786-246-0787 ralph
http://i11.photobucket.com/albums/a1...amera057-1.jpg
http://i11.photobucket.com/albums/a1...amera056-1.jpg
http://i11.photobucket.com/albums/a1...amera055-1.jpg
http://i11.photobucket.com/albums/a1...amera054-1.jpg
http://i11.photobucket.com/albums/a1...amera053-1.jpg
http://i11.photobucket.com/albums/a1...amera052-1.jpg
http://i11.photobucket.com/albums/a1...amera051-1.jpg
http://i11.photobucket.com/albums/a1...amera050-1.jpg
http://i11.photobucket.com/albums/a1...amera049-1.jpg
http://i11.photobucket.com/albums/a1...amera048-1.jpg
http://i11.photobucket.com/albums/a1...amera047-1.jpg
http://i11.photobucket.com/albums/a1...amera040-1.jpg
http://i11.photobucket.com/albums/a1...amera039-1.jpg
http://i11.photobucket.com/albums/a1...amera038-1.jpg
http://i11.photobucket.com/albums/a1...amera037-1.jpg
http://i11.photobucket.com/albums/a1...amera036-1.jpg
http://i11.photobucket.com/albums/a1...amera035-1.jpg
http://i11.photobucket.com/albums/a1...amera034-1.jpg
http://i11.photobucket.com/albums/a1...amera033-1.jpg
http://i11.photobucket.com/albums/a1...amera032-1.jpg
http://i11.photobucket.com/albums/a1...amera031-1.jpg
http://i11.photobucket.com/albums/a1...amera030-1.jpg
http://i11.photobucket.com/albums/a1...amera028-2.jpg
the yellow stuff on the crank journals and the cylinders is lithium grease to protect against rust.
this swap is from my 01 ITR which i am also selling
am willing ot sell the car seperate, or sell the car witht he numbers matching engine and transmission.
regardless if someone buy everything and puts it together they'll have something worth alot more than w hat they'll pay
open to trades, offers, ideas, even constructive criticism.
thank you
Parting that swap out would be your best bet on this forum or for any forum for that matter but if you still want to sell as a whole I'd recommend ebay or a local sale because it's useless on here.
just my .02 cents
just my .02 cents
RIP V8s
Nov 12, 2007 11:28 PM
Lsssleeper Coupe
Mar 24, 2005 02:15 PM
