need a vacuum hose diagram with labels 1989 Accord LX/Carbed
Trying to trace a vacuum leak. Car not running well.
I only have the factory/stock picture glued to the hood underside.
Some of the items connected to vac hoses are labelled, but some are not.
Does anyone have a picture where all the items are labelled as to what they are?
example: on the p-side, above intake manifold, hose 16 connects to a labelled device called: "EGR VALVE". Hose 16 ALSO activates a vacuum
"solenoid" that connects a larger rubber hose from the air filter base, to an device that has 2 wires coming out of it. I want to know what that electrical thing does, and what it is called..........................there are also many other unlabelled devices that I'm trying to trace out.
Can someone direct me to a labelled pic of what things are attached to vac
hoses?
Thanks in advance.-Bob
hoses?
Thanks, HondamanWill,
You can send the 89 Honda Accord/ carburator vacuum line diagram
with labels to bobfixesitup@yahoo.com
