f/s 1994 honda civic 4 door DX s. california new motor
Old Apr 22, 2007 | 07:03 PM
wesuri's Avatar
Default f/s 1994 honda civic 4 door DX s. california new motor
1994 honda civic 4 door eg (34mpg +)
DX model, upgraded from 1.5 to 1.6 ZC motor
Drivers side and passengers side air bags
motor replaced 6,000 miles ago
stock motor replaced with 1.6 ZC rebuilt by gspeed in torrance, CA
replaced: new timing belt, water pump
all seals, belts replaced
AC charged up, no leaks, blows cold!
Power steering fluid flushed,
brakes flushed with dot 3/4 fluid
New axles and new axle nuts (both right and left side)
New brakes (rotors slotted and cross drilled)
portifield pads
Rear disc conversion
new theromostat
new spark plugs, spark plug wires, cap and rotor
JDM amber clock
JDM/USDM guage cluster hybrid (reads MPH)
Type R shifter
Falken ziex 512 tires
JDM rear control arm
JDM corner lamps
JDM rear sway bar
OEM front strut tower bar
TEIN coilovers
K&N cold air intake
Cusco spin turn ****
Problems with the car:
rear right window doesnt roll down,
Drivers side window is hard to roll down.
pilot bearing needs replacing
horn button broken
also, not pictured...
my friend gave me some gray civic coupe floor mats, i will include these with car,
also have repair manual and original springs and shocks.
Old Apr 22, 2007 | 08:33 PM
drewbie*'s Avatar
Default Re: f/s 1994 honda civic 4 door DX s. california new motor (wesuri)
how much did you want for it?
Old Apr 22, 2007 | 10:12 PM
FATninja19's Avatar
a little work with cleaning products and that car would be clean!
Old Apr 25, 2007 | 03:10 PM
wesuri's Avatar
thanks
Old Apr 25, 2007 | 07:50 PM
wesuri's Avatar
Default Re: (wesuri)
2700$ for the car, and 1000$ for all the aftermarket and JDM goodies
the break down for the 2700 goes as follows, 2000 for the car its self, and 600$ for the rebuilt motor, and 100$ for all the new parts, ie, timing belt, axles, brakes, water pump, etc)
3700$ as is,
or i can take the goodie parts off and let it go for 2700 with only car and engine.
Old Apr 25, 2007 | 07:51 PM
wesuri's Avatar
A/C, heater, brakes, clutch, steering, battery, just about everything rungs strong. good for daily driver.
Old May 1, 2007 | 01:50 AM
wesuri's Avatar
forgot to mention that i will wash the car before purchase!
REALLYQUIETMAN
Aug 30, 2016 06:52 PM
wesuri
Feb 16, 2009 10:55 AM
sheizen
Aug 9, 2008 08:34 PM
