Wing Removal Help
Old Apr 22, 2007 | 03:53 PM
RStoR's Avatar
Default Wing Removal Help
1st - Yes I've read all the searches on "wing removal."
2nd - I've got a Mugen wing that's coming off the car. I purchased my ITR with it mounted so "I'm assuming" it's the Mugen supplied double sided tape.
3rd - I tried removing the wing today via the "dental floss" trick. It was 80+ deg. outside so it should have been warm-hot. Single floss, double floss, regular & glide were tried, double sewing tread was tried too. All just shredded after 1-2 sawing motions.
4th - Anyone got any other ideas? Would fishing line scratch the paint?
Edit: Stop IM'ing me...the wing is already commited to someone
Modified by RStoR at 8:44 PM 4/22/2007
Old Apr 22, 2007 | 04:10 PM
ZygSpeed's Avatar
Default Re: Wing Removal Help (RStoR)
Sorry, I'm not much help on this one.
Maybe some mild solvent, or something like bayby oil?
Old Apr 22, 2007 | 04:16 PM
Rzoops's Avatar
Dibs on Mugen wing after it's removed??
Old Apr 22, 2007 | 04:43 PM
Dave_B's Avatar
I'd say some 20 lb test fishing line should do it. Just force the line up, into the wing, not down on the paint.
Old Apr 22, 2007 | 05:48 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">so "I'm assuming" it's the Mugen supplied double sided tape.
I'm not sure, but doesn't the wing bolt on as well. I'm pretty sure the Gen 1 wing does and I know the Gen 2 replica does and would assume the same for the authentic.
Ignore this comment if you already took off the hatch plastic and unbolted it.
Ali
Old Apr 22, 2007 | 06:08 PM
RStoR's Avatar
Default Re: Wing Removal Help (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure, but doesn't the wing bolt on as well.
Ali</TD></TR></TABLE>
It does bolt thru the OEM wing holes - 2 bolts each side. No plastic removal needed. That was done before I attempted the dental floss trick.
Old Apr 22, 2007 | 06:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Dave_B)
I used some fishing line on mine, as Dave_B suggested. I also found that some WD-40 sprayed beneath the base of the wing and onto the fishing line helped the process along.
Old Apr 22, 2007 | 06:40 PM
Spids5's Avatar
Don't judge or question
Default Re: (Padawan)
Use a guitar string if you have one to cut through the double sided tape and it will come right out. The guitar strings works better than fishing line but the fishing line will do if that is all you got.
Old Apr 22, 2007 | 07:31 PM
Doespike's Avatar
Edit: Stop IM'ing me...the wing is already commited to someone </TD></TR></TABLE>
LMAO!!
Sorry, no other suggestions than what's already been mentioned.
Old Apr 24, 2007 | 01:30 PM
Hooch'n's Avatar
Default Re: Wing Removal Help (Doespike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">
LMAO!!
Sorry, no other suggestions than what's already been mentioned.</TD></TR></TABLE>
i have a suggestion.......come out and track that ride....
Old Apr 24, 2007 | 01:44 PM
Casey's Avatar
Default Re: Wing Removal Help (Hooch'n)
chris...there are 2 brackets on each side of the wing clamping it to the trunk lid with grub screws. id take a pic of the one i have left, but im lazy and im only mentioning them bc sometimes the obvious answer isnt the easiest to get
min_kw
Honda S2000
Apr 9, 2009 07:20 AM
mipawi
Apr 12, 2005 06:00 AM
Haleiwa-Brando
Sep 22, 2004 05:13 AM
nsx-Animal
Jun 20, 2002 08:56 PM
Ross
Nov 29, 2001 08:47 AM
