Question about Energy Suspension motor mount inserts
Old Apr 22, 2007 | 12:33 PM
Secret Chimp's Avatar
Default Question about Energy Suspension motor mount inserts
I have a bad front motor mount (rubber is shot, bolt riding on the mount metal), but I've deemed it physically impossible to reach the rear-facing frame bolt (underneath the through-bolt flange, up against the transmission).
I can't find anything on actually installing Energy Suspension poly mount inserts, so I was hoping that somebody here has installed them on their 94-97 Accord. Does installation require actual removal-from-frame of the front mount, or just removing the through-bolt and attaching the inserts to the interior and sides?
Old Apr 22, 2007 | 05:45 PM
Turbowa's Avatar
Default Re: Question about Energy Suspension motor mount inserts (Secret Chimp)
If the rubber in the middle is shot then you need to replace that mount before putting the insert in. You will take the 3-14mm bolts out of the top of the metal mount that attaches to the motor. Then you can take out that center bolt and remove that metal piece. Once this is out of the way you can remove that mount from the sub-frame rather easy.
But replace the broken mount first before putting in the poly mount. They are not suppost to be used to fix broken mounts.
Old Apr 22, 2007 | 06:30 PM
japspecb7's Avatar
there not suppose to be used to fox broken mounts but hey work very well when used.
RNPoo7
Mar 28, 2007 01:16 PM
timisyourfriend
Aug 1, 2005 05:41 AM
Tire Monkey
May 1, 2004 12:38 PM
Thundersquid
Oct 23, 2003 10:43 PM
