Replacing distributor rotor?
Old May 28, 2002 | 09:43 PM
93SSPHatch's Avatar
Default Replacing distributor rotor?
I have a 1993 Honda Civic CX. . .
Please help. . .i've taken off the dist. cap. . .and I am now trying to replace the rotor. . .unfortunately I cannot get it off! My Haynes manual says that there is a retaining screw that holds the rotor to the distributor. I cannot find this screw for the life of me!!
Can someone take a digital picture. . .or post a picture of this mysterious screw, or can someone direct me in the direction of this screw and how you take the rotor off! Thanks
Where is a good online store to buy OEM Honda Parts?
[Modified by 93SSPHatch, 10:48 PM 5/28/2002]
Old May 28, 2002 | 09:57 PM
93SSPHatch's Avatar
Default Re: Replacing distributor rotor? (93SSPHatch)
ttt.. . does anyone know where I can find the company names of the OEM parts. . specifically the dist. cap, dist. rotor, and fuel filter
Old May 28, 2002 | 10:00 PM
Gump's Avatar
Take off the cap, you will see the rotor, just below the rotor there is a black piece of plastic, take it off by just pulling down on it, look for the screw, it should be on the rod part of the rotor.
[Modified by Gump, 11:01 PM 5/28/2002]
Old May 28, 2002 | 10:04 PM
NismoNX's Avatar
Default Re: Replacing distributor rotor? (Gump)
The screw is pretty small, but you should be able to find it.
Old May 28, 2002 | 10:20 PM
93SSPHatch's Avatar
Default Re: Replacing distributor rotor? (NismoNX)
Thank you so very much. . .I can now complete my "maintenance" in the morning. . .for now, it is bed time.
Old May 30, 2002 | 02:57 PM
cr00klyn718's Avatar
If you don't see the screw just crank your car(rotor will turn,you should see the screw) leave the distributor cap off when cranking. Good luck!!!
Old May 30, 2002 | 03:04 PM
93SSPHatch's Avatar
Default Re: Replacing distributor rotor? (cr00klyn718)
Thank you!
thefew
Dec 2, 2015 06:44 PM
Smccorkeljr
Jan 8, 2015 06:08 PM
218luder
Feb 7, 2008 08:39 PM
Truman001
May 30, 2006 06:07 PM
stock_cx
Feb 6, 2005 03:07 PM
