wtt b swap parts for turbo parts
Alright yal I got a good deal on an almost complete B swap and thought i'd be going that route but have changed my mind.
The specifics of what I have:
B18a1 shortblock. The car it came out of was running, but I took it apart due to my intention to build it. Complete with pistons rods, crank, all hardware, oil pan, flywheel, etc.
Have a b18b1 head with cams, cam gears, valve cover. Needs only valve cover bolts. Comes with distributor.
Hydraulic LS transmission in good condition.
Also have:
-Manual rear integra bracket
-Integra Driver side post mount
-Integra Shift Linkage w/shifter
-B Series Starter
-LS Intake manifold
-Integra Half Shaft
-Fairly new Integra Axles
Important stuff not included:
-No headbolts
-No clutch
-No pressure plate
-No Throttle Body
-No Alternator
-No Throttle Cable
-No oil pump
-No water pump
-No front main seal
-No header
*Also have a GSR Distributor that needs a new harness connector i'll throw it in if desired.
Alright now that that's all out the way i'm looking for D series turbo kits/components.
Prefer a Edelbrock kit.
Am open to Greddy kit, or homemade kits, etc.
Let me know what you have.
Thanks for looking
Also have:
-B Series Starter
-LS Intake manifold
-Integra Half Shaft
-No headbolts
-No clutch
-No pressure plate
-No Throttle Body
-No Alternator
-No Throttle Cable
-No oil pump
-No water pump
-No front main seal
-No header
Thanks for looking
manveer
Nov 22, 2003 10:07 AM
