ignition output signal HELP!! PW0, B15 B17 PINS
Today i was looking over the butchered wiring harness i got with my EF B16, anyway as i was pulling out the B plug both wires from B15 and B17 came undone, i wired them back up now the car wont start, i think i may of mixed up the wires!!!!, i know there both ignition output signal but i cant figure out where they go on the distributor, can anyone tell me where these wires go to so i can try and run direct wires. THANKS
Modified by eth0r at 11:22 AM 4/22/2007
i have a b16a w/ hondata and i had the same problem, not the wires crossed but i got that code, i changed the ignition moduel and nothing, and the coil tested good, still cant figure it out....
managed to fix it, apparently B15 and B17 pins, merge together somewhere up the line, so i wired them together and ran a fresh wire to the white dizzy wire, swaped dizzy becasue i think i fried the ignitor when i mixed up the wires.. but she lives again!!
thanks vw eater for replying
Fuk SALT
10
Mar 4, 2009 02:47 PM
