HELP PLEASE!!!
Old Apr 21, 2007 | 06:56 PM
primetimeracing's Avatar
Default HELP PLEASE!!!
So im pretty much new to the honda-tech forum...but ive been on here much before jsut never posted...but i resently wrecked my 91 accord...it was totaled but i managed to fix it to drive and be legal...it had no hood on it and it rained(my luck) but after it got done raining it still cranked right up..so i decided to drive it to work. I got off work and went to crank it and nothing..i replaced the dis. cap, button, and wires...it still wont crank though..ive let it dry out for a week and still nothing..ive checked all fuses and nothing is blown..i need something to fix this...its killing me i need my car back!
Chris
Old Apr 21, 2007 | 11:16 PM
be8teensee1's Avatar
Default Re: HELP PLEASE!!! (primetimeracing)
well the first thing to do is check for spark. if its getting spark then check if its getting fuel ....hold on is it even trying to crank?
Old Apr 21, 2007 | 11:30 PM
CB7 ghost's Avatar
CHeck your starter if it doesnt crank over.
Old Apr 23, 2007 | 01:26 PM
it tries to crank..it will turn over but it never cranks...the battery is to dead to check for spark now since i tryed cranking it so much. what would be a reason its not gettin gas?? i has a full tank..how would i go about changing the coil??
Chris
Old Apr 23, 2007 | 04:43 PM
bump
Old Apr 24, 2007 | 06:36 AM
notoriousB's Avatar
Default Re: (primetimeracing)
check to see if you are getting spark at the plugs. use another car w/ jumper cables if the battery is dead.
if you are then check to see if you're getting fuel.
you are missing one or the other if it cranks but does not start.
stop throwing parts at it you are wasting your money. if you can't do these two tasks I suggest you contact a mechanic.
Old Apr 24, 2007 | 12:27 PM
surfer_mom3's Avatar
hey try checking the altenator that may have gotten wet and poss shorted out .
Old Apr 24, 2007 | 04:33 PM
Default Re: HELP PLEASE!!! (surfer_mom3)
would that cause it not to crank???
Old Apr 24, 2007 | 07:09 PM
the car can still run with a bad altenator .. until the battery dies, in your case your battery died from cranking and cranking ... like i said before CHECK FOR SPARK AND GAS if you dont know how to check for spark they sell spark tester's that you plug into your plug wire and it will light a bulb every time the car cranks..if its not getting spark check the coil / if it is getting spark loosen the fuel line on the fire wall going to the filter on have someone turn the key on , but dont start the car just turn the key until the fuel pump primes . there should be gas squirting out ( use a rag or a cup to catch the gas and watch your eyes lol ..... find your problem first , then you buy the parts. dont go buying stuff you dont need
Old Apr 25, 2007 | 12:43 PM
ok im not getting spark..how can i check the coil...
Chris
Old Apr 25, 2007 | 03:17 PM
whelp yall where right..shouldnt just throw parts at it..i put a new coil in it and it still doesnt crank..it still isnt getting spark..what else could be wrong!?!?!?
Chris
Old Apr 25, 2007 | 04:49 PM
BLKFLSH's Avatar
Alternators get wet all the time. They don't short out from that. I wash my engine off at the carwash, no problem.
Old Apr 25, 2007 | 05:12 PM
Default Re: HELP PLEASE!!! (BLKFLSH)
well whats wrong with my car then?!!?
Old Apr 26, 2007 | 03:17 AM
TTT
Preludelearner
Mar 26, 2015 07:54 PM
B_Swapped93
Apr 22, 2013 10:12 AM
91grape
Aug 6, 2012 06:31 PM
mygfs92lx
Jul 19, 2006 06:33 PM
DCtwoR
Jun 20, 2002 07:10 PM
