New here...wheel question
Old Apr 21, 2007 | 12:03 PM
hondahotrod's Avatar
Default New here...wheel question
Hey all, new here as of today. Own an '01 Accord LX V6 with the nasty LX V6 covers for wheels. Trying to figure out is the stock LX V6 wheels from a 2007 Accord LX V6 would fit on the car. This new wheel is 17x6 5-lug. The wheel on the '01 is a 15x6.5 5 lug. Wondering what the bolt pattern is on the new wheel. Called the honda parts department here in Spokane yesterday and they didn't know...Anyone have any experience with this?? I want to put Honda wheels on the car just to maintain some originality of the car if you will. I don't really want to put aftermarket wheels on it so...thanks!!
Old Apr 21, 2007 | 12:25 PM
BLKFLSH's Avatar
Default Re: New here...wheel question (hondahotrod)
I'm about 90% sure they will fit. You may want to wait for someone else to respond who is 100% sure.
Old Apr 21, 2007 | 02:52 PM
Default Re: New here...wheel question (BLKFLSH)
Thanks for that...the parts department also said that the hub size was different. I'm assuming that doesn't matter if the hub is larger on the newer cars than the '01. I can use centering lug nuts or something like that to solve that issue. The dilemna arises if the hub is smaller on the newer cars...then it won't be nearly as easy.
Old Apr 22, 2007 | 09:25 AM
schweppyaccord's Avatar
I'm assuming that the steel wheels are what you have on your car now. The bolt pattern should be the same for both of the weels. The only place it might get tricky is with the offset of the new wheels. However, since the 17" wheels on the 07 and only 17x6.5", the same width as your current wheels, it souldn't make too much of a difference. However, to be 100% sure before you make the purchase, check with the Honda dealership about the specific swap.
bgibbs11
Jan 23, 2011 08:14 PM
sleepywagon627
Dec 30, 2010 12:20 PM
microjubei
Honda Civic (2006 - 2015)
Apr 26, 2006 11:43 AM
mikerst
Sep 25, 2005 08:33 PM
mk3veedubjetta
Feb 14, 2005 05:07 PM
