NOOB question....Mini-me
Old Apr 21, 2007 | 06:58 AM
tihz_wa's Avatar
Default NOOB question....Mini-me
This is kinda a noob question and i'm sure its been asked before, but i can't seem to find the exact info i'm looking for....
I have a 91 CRX dx...can a z6 vtec head bolt up and work...or do I need an si block? will it be worth it in the end?...what kind of numbers to expect? any info will be awsome. Thanx guys!
Old Apr 21, 2007 | 07:21 AM
SIred91's Avatar
Rainman
Default Re: NOOB question....Mini-me (tihz_wa)
Yes, it will "bolt right up" But use the headgasket for the head you will be using.
Get the ECU for the head you will be using as well. If you don't, vtec will not engage prperly and you will eventually damage your motor.
Go to http://rywire.com for all the wiring, he can make it all plug and play for you.
You will also have to change your wiring from dpfi to mpfi, that is all covered in the FAQ at the top of the page, as well as the write ups for a mini me swap.
Have fun.
powersk8er92
33
Nov 29, 2011 12:20 PM
fallrivercolin
Nov 5, 2011 04:34 AM
hondawhat?
20
Dec 14, 2010 10:07 AM
92ehatch
22
Mar 13, 2010 11:56 AM
zenon8890
Nov 22, 2008 12:20 PM
