3 layer OEM head gasket thickness (mm) ?
Old May 28, 2002 | 07:24 PM
pinota's Avatar
Default 3 layer OEM head gasket thickness (mm) ?
Hi,
Anyone know the 3 layer OEM head gasket thickness (mm) ?
Thanks,
Pinota
Old May 28, 2002 | 07:59 PM
pinota's Avatar
Default Re: 3 layer OEM head gasket thickness (mm) ? (pinota)
Just did some search and i think it´s 0.6 mm.
thanks,
Pinota
Old May 28, 2002 | 08:06 PM
RTW DC2R's Avatar
Default Re: 3 layer OEM head gasket thickness (pinota)
That sounds about right...Spoon's 2 layer gasket is about .45mm, and the Mugen gasket is about .47mm...both of which are thinner than the OEM 3 Layer.
Old May 28, 2002 | 08:29 PM
comptechgsr's Avatar
Default Re: 3 layer OEM head gasket thickness (RTW DC2)
is it possible to just use a single layer....off the oem 3?
i know some foolz have used 2
Old May 28, 2002 | 09:30 PM
JSIR's Avatar
New User
it is .028" compressed, convert that to mm, I believe it is .71 mm. Yes you can use any combination of the 3 layers, one, two or three layers as long as it is installed properly on a flat head/block surface - not overly warped parts. The middle layer is slightly thinner than the other two layers also if that matters.
Eghatchgsr8
Sep 19, 2014 02:24 PM
ge_itr
Jan 9, 2007 08:58 PM
tunerraceteam
Jan 7, 2006 02:32 PM
bcube 1
Apr 26, 2005 10:23 PM
