Difference between 2 of these H&R springs.. Curious
Old May 28, 2002 | 07:23 PM
rsx03's Avatar
Default Difference between 2 of these H&R springs.. Curious
Guys I am looking into H&R Stage 2 sports lowering springs for my 01 GSR.
there are 2 part #'s to tell these springs apart along with 2 different lowering heights.
1. Integra Typ DC 1994-01 "not Type R" 1.75 1.5 part #50145
2. Integra Type R 1996-01 1.5 1.3 part #29502
Does anyone know why these are different?
Will the Type-R ones fit my GSR stock shocks ok?
Old May 28, 2002 | 07:32 PM
uNF$@#!'s Avatar
Default Re: Difference between 2 of these H&R springs.. Curious (2K1GSRBOY)
50145 will drop your car 1.75"
29502 will drop your car 2.5" (1.5" + 20 mm)
i would not suggest getting 29502, but do whatever you would like.
Old May 28, 2002 | 07:53 PM
rsx03's Avatar
Default Re: Difference between 2 of these H&R springs.. Curious (00-0187)
WHAT!! are you serious. How can the drop result in 2.5" drop ?
It say's 1.3" - 1.5" what the hell..
[Modified by 2K1GSRBOY, 8:56 PM 5/28/2002]
Old May 28, 2002 | 07:54 PM
tatty's Avatar
New User
It say's 1.3-15" what the hell..
I'm guessing from stock GSR height...
Old May 28, 2002 | 07:55 PM
EagleR's Avatar
The type R is lower than yours to begin with, so he added the factory drop to the springs advertised drop...
Old May 28, 2002 | 09:23 PM
t's Avatar
t
Default Re: Difference between 2 of these H&R springs.. Curious (EagleR)
You cant add the factory drop because it is the ITR springs that drop it. Take out the springs and put in GSR springs and it will be regular Integra height.
So, If you take out the ITR springs and replace with 1.5" drop springs, Wouldnt your car be 1.5" drop?
Old May 28, 2002 | 09:26 PM
t's Avatar
t
Default Re: Difference between 2 of these H&R springs.. Curious (t)
Also, I believe the ITR is 15mm drop not 20mm. And 20mm does not equal 1 inch.
Old May 28, 2002 | 09:34 PM
RagingAngel's Avatar
Where's Ddub to check this thread? He actually had the very discussed spring on his car a week ago.
The lowered ride height of the ITR specific springs aren't that low at all...they are a SPORT spring and not a RACE spring.
Something interesting though.... when we put identical kg/mm DR Racing springs into one DC2 and one DC2-R.
The DC2 was actually lower than the R.... I wonder if it is because the OE dampers have more compression rebound or the weight of the GS-R sags the car more....probably the latter....
Old May 29, 2002 | 05:27 AM
rsx03's Avatar
Default Re: Difference between 2 of these H&R springs.. Curious (RagingAngel)
Yeah where is Ddub? I would really like to know about this .
I would like to get the H&R because of the drop they give, but i just want to know if they will fit on my GSR shocks and will they ONLY be 1.5" and no more lower
so someone please clearify this
Old May 29, 2002 | 05:51 AM
Dr Pooface's Avatar
GSRs ride higher than R's. If you put a lowering spring for an R in the drop will be more than advertised, but will go to the same final level. IE will drop an r from 6 inches down to 4 inches off the ground (2 inch drop) but will drop a gsr from 7 inches down to 4 inches (3 inch drop). The lower ride height of the r spring will kill your gsr shocks.
Old May 29, 2002 | 11:53 AM
t's Avatar
t
Default Re: Difference between 2 of these H&R springs.. Curious (Ddub)
Why would it be?
Old May 29, 2002 | 12:34 PM
slivic's Avatar
Because a type r is lower then a GSR to begin with!!!!
Old May 29, 2002 | 01:28 PM
t's Avatar
t
Default Re: Difference between 2 of these H&R springs.. Curious (slivic)
Type R is lower because of the springs that you are going to replace.
Type R springs lower the car approx. .75"
H&R springs lower the car approx. 1.5"
Remove the .75" springs and replace with the 1.5" springs, Doesnt that equal car lowered 1.5"?
Now why would it be lowered than advertised?
[Modified by t, 2:31 PM 5/29/2002]
Old May 29, 2002 | 01:34 PM
IntegraT's Avatar
*sigh*
Old May 29, 2002 | 02:12 PM
EagleR's Avatar
Default Re: Difference between 2 of these H&R springs.. Curious (IntegraT)
I'm just guessin on mine...I have 0 experience with a GSR to know the diff
Old May 29, 2002 | 02:29 PM
yoshi234's Avatar
I shoot brides
TonyRomo
Jun 9, 2008 10:08 PM
aln2590
Apr 16, 2007 07:22 AM
Tomakit
Jul 1, 2003 12:34 PM
Peter K
Jul 4, 2001 02:59 PM
