clutch problem on 98 acoord F23
Old Apr 20, 2007 | 12:20 PM
5lugcivic's Avatar
Default clutch problem on 98 acoord F23
we finish installing a new clutch on this 98 accord. started up the car, while the car is still on jack stand, shift to gear the wheels spins even with clutch hold all the way down. we bleed out the clutch fluids but doesnt seem like its pumping it out. can this be a bad clutch MC? now the clutch pedal hangs and wouldnt push the slave cylinder.
we did not resurface flywheel. can this be a problem? i wouldnt think so from my past experience.
the old clutch came out broken. not worn out. pads were broken off the clutch itself and includes all the bad smell of burning clutch.
Old Apr 20, 2007 | 06:35 PM
standbackimapro's Avatar
its supposed to spin a little, put it on the ground the car wont move or anything
Old Apr 20, 2007 | 07:13 PM
5lugcivic's Avatar
Default Re: (standbackimapro)
yes i know it will spin alittle but while holding the brakes on it will grind before going into gear. will not go into gear easily as well.
ksherry
Dec 16, 2010 03:03 PM
93civcx
Jun 18, 2004 06:25 AM
esoterEK..
Oct 5, 2003 10:26 AM
