help with my eg coupe .......please
i have a 95 coupe ( eg ) and for some odd reason i cant get the back right blinker to work.... it was working fine and then one day it just went out. i know i know i already changed the bulbs and that diddnt help. i played with the wires a little and it went on but then just went off so im a little stumped ??? can some one ....any one help...? i am clueless at this point.
thanks
J
thanks
J
try tracing the wire using the diagram above ..if your not blowing fuses its probably not a short causing wire with the insulation worn through.. most likley a loose connection like Padawan said.. good luck
dez6
Nov 3, 2010 05:56 PM
AcuraEL
Jul 10, 2003 03:35 PM
