electrical problem in dash...
Old Apr 20, 2007 | 07:34 AM
rustedcx's Avatar
Default electrical problem in dash...
i searched, but had no luck....
the other day, all my guages seemed to go dead-speedo, temp, gas, and odometer... but i still have the dash and warning lights in the cluster?!
at the same time i lost my turn signals, but the stick still does the highbeams, so the stick seems to work
i checked all the fuses under steerinng wheel and hood.... all good
i checked owner's manual and none of the fuses are listed as doing the guages or signals, just the hazards... but they work
has anyone ever had this problem?
94 cx
all stock
no other problems, just rust and this electrical problem
PLEASE HELP
Old Apr 20, 2007 | 07:46 AM
umop-apisdn's Avatar
Default Re: electrical problem in dash... (rustedcx)
Find a Helm's and check all of the grounding leads.
Old Apr 27, 2007 | 04:24 AM
chuckc417's Avatar
I just had this problem myself, took me a year to figure it out, what i did finally to get it working was pulled the plug out of the VSS and sprayed a little DD40 in it. Also check the fuse under the wheel that says backup lights, this too controls you gauges. As far as my turn signals, i have not found out what is wrong with them yet, what i had to do is go behind the switch, and run a new wire between the switch and the head light, and go to auto parts store and buy to 2 prong flashers and hook them upto the wires, this will get you blink back. I can not find where the turn signals go to flash. Its wierd. my yahoo SN is chuckc417, also email. Contact me if you need anything else. Good luck. Also ill post a fuse breakdown o here for you.
Old Apr 27, 2007 | 04:29 AM
chuckc417's Avatar
Default Re: electrical problem in dash... (chuckc417)
http://autoforums.carjunky.com...3020/
follow that link, look in there you will find 92-95 civic fuse breakout, 3 fuses control the gauges.
Murz
Nov 5, 2007 09:04 AM
jaydmhatch
Mar 3, 2006 05:06 AM
Gotturbos
Oct 17, 2004 08:35 PM
anothersickhatch
Apr 1, 2004 12:38 AM
btlfedhatch
Jul 24, 2002 09:25 AM
