Wiring Harness!!!!!!!
I recently bought the shell for a 99 Honda SI, I'm planning on putting on a B16A, OBD1, I wanted to know if the harness on the B16A2 will fit in the motor, or what do u guys suggest I do? Also, I have a P28 & I wanted 2 know if it will work in this motor. Thanks 4 u'r help!
the harness of the 99-00 civic si will work, your going to have to change some of your plugs to OBD1(dizzy,alt.,injectors,etc.) or change your things to OBD2b(dizzy,injectors,alt,etc.), as for the P28 youll need a OBD2b-OBD1 jumper harness and have it chipped for a DOHC VTEC base map or find a P30.
ok like he said everything will clip right up actually if im not mistaken the dizzy alt and what not will also clip right on but i could be wrong nething grey plug will clip right up to grey plug now as for the ecu's u will need the obd2 to obd1 jumpper
tdbhonda
Mar 16, 2009 06:39 PM
Ef88Lsvtec
Aug 9, 2008 04:54 PM
ixoiiiiviviiivi
Oct 30, 2007 04:21 PM
